How to get iPod-like functionality from a burnt DVD-R (PCM 3.0, PCM 3.1, CDR 31)
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
(Will edit again with more detailed pictures when i get my Cayenne in 1-2 weeks)
figured this out when i had my Carrera 997.2, (Does NOT work on 997.1)
basically, this enables to to burn your home collection of music onto a DVD-R (4.7GB single layer or 8.5GB dual layer (note the dual layers sometimes are problematic to read)) and display the CD's just like an iPod hookup would display them on your PCM screen (Artists-->Albums-->Tracks).
this is directions for MAC owners, however PC users should be similar (Drag from the iTunes Folder (not from iTunes directly)) if you burn from iTunes it usually burn's them as apple format which does not read all the time on the PCM.
1: Insert the blank DVD-R into your CD/DVD drive (do not touch the back as they are very sensitive)
2: Prompt will show up asking what you wish to do with the DVD,
3: Click the prompt to "Open in Finder"
4: Window will open as shown:
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/2.jpg)
5: Click "CTRL+N" to open another window in FINDER
6: Window will open as shown:
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/3.jpg)
7: Left hand side you can click your computers name and then the "music folder" as highlighted above, OR music on the left and then will bring you tonext screen.
8: Window will open as shown, Click "iTunes"
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/4.jpg)
9: Now Click "iTunes Music":
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/5.jpg)
10: Select Artists you want (can either click and drag over desired artists one by one, OR hold command while clicking the artists you want (selects more than one) and drag into DVD-R folder, or select multiple folders and drag all over)
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/6.jpg)
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/7.jpg)
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/8.jpg)
![](http://i85.photobucket.com/albums/k43/rijowysock/SRS%20light/9.jpg)
11: Now u can "right click" in the white area in the DVD-R finder and click "Arrange By" and then "Name" this will sort the Artists all alphabetically (Easier to find when in PCM)
12: Click "Burn" (bottom right of Finder Folder)
13: Insert DVD-R into the PCM and it will take maybe a minute to load and then the screen should show the DVD.. click for artists listed, click artist to see albums, click album to see tracks, click track to start playing.. will play to the end of the Album, then onto the Next album as sorted on the DVD.
(Note: if you drag an artist into the DVD-R finder folder and then change your mind, you gotta drag it back into the other finder... if you click delete, sometimes it tries to delete it from your "itunes" folder... so just pick what you want and keep an eye on the total folder size at the bottom of the finder window.)
-Riley
Can play: Pandora, XM, Other Internet Radio, or Any sound from iPhone/iPad/Touch thru PCM via Bluetooth.
(more detailed instructions once Cayenne Arrives)
1: Link phone to car via Bluetooth
2: Set audio source on PCM to "BTAudio"
3: Now anything you select to play on iPhone/iPad/Touch will play over the Car's Audio System (Pandora, iPod, Games, Internet Radio, Etc)
-Riley
Wonder if this will work in my Bose CDR-30 in my 2011 Cayman.
Nothing that unusual about that ... its exactly what should be happening when you burn 4-8gB of supported music files to a DVD-R and insert it into the disc player.
Mine always has a disc in it and the player is set to shuffle. My own, commercial free, interference free, audio source that costs $0/day to operate.
