Anyone looking for a 3,075lb 1:1 EXACT 997 replica?
Because I have one sitting in my garage.
Apparently, the '07 CPO that I purchased three months ago was sold to me with a battery that had expired three months before I purchased it. Result is that I have a brick for a sportscar.
I simply can't believe this kind of stuff is allowed to go on in the CPO process. "Oh, he'll never notice it. And when it dies on him any day, we can charge him for a new one!!"
Its being towed to the dealership right now and it WILL have a replacement battery put into it free of charge or I WILL raise holy hell.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Poseur
What do you mean that the battery 'expired' 3 months before you bought the car?
Was the car operational when you test drove it?
Is the condition of the battery a factor in the inspection of a used car? Are you suggesting that it was just barely holding on as you bought the car?
Batteries have expiration dates. Mine expired in January 2010.
Been sluggish to start over the last week until dead as of this morning. Now it explains the sugglish ignitions.
And yes, one would think that a dealership would swap out an expired battery on a CPO car that is sold at a substantial premium.
I'm not off base here. Seems pretty reasonable.
What does it mean, "a battery that had expired three months before I purchased it"?
Batteries aren't like a perishable food item that have expiration dates. They are good to go for as long as they may or may not last, and then they die. End of story.
How many miles on the car? Porsche will not warranty batteries in cars that are driven less than 6k miles per year. You may want to reconsider the "raise holy hell" thing. You're getting all worked up over spilled milk. If they owe you a battery they'll give you one. If they don't, they won't. Fairly straight forward stuff.
I have a feeling you've been letting the car sit idle in your garage? That would make it your fault if it wasn't on a battery charger.
Phil
Phil
Phil
Phil
And battery warranties are clearly there for a reason.
Poseur
I had to purchase a new battery for my car in 2010 (earlier this year) because it was not holding up. I expect it to be a fair wear and tear item on any car. They generally fail prematurely on cars that are not driven enough. You never state the miles on that used car you purchased.
You can look at the CPO checklist to see if there is any mention of the battery. If it is not one of the CPO inspection items (and I doubt if it is), you are probably sol on this one.
However, the sluggish starting might indicate a problem that also affected the battery - the ground to the engine or other cables may be bad (search the board, there have been some posts about this). If so, they should replace those cables at no charge and your old battery, once fully charged, might be ok for a while longer (I doubt it because of its age and because car batteries don't like to be discharged past 1/2).
Admin
For the OP.
This is normal and correct that they left the battery in the car as long as it was the oem battery (even if it was expired one year ago) otherwise they are in breach of their obligation regarding warranty and dealer check list.
Ergo if the battery is oem it has a warranty from its manufacturer that has nothing to do with your cars warranty that comes from Porsche for the whole car with the known exceptions and covered period. So as long as you are entitled for warranty for the battery you will be covered without making a scene or give hell about it.
John
John
Poseur
Here's what you need to do when you obviously don't drive the car that much. (Although you do better with the concours crowd). Get a trickle charger.
