Quick window grease question..
Both 997's whenever I put window down I get greasy smudge lines on interior of window and sometimes exterior. Cleans off but always comes back. Car is garaged so not like sap or something getting down there. Anyone else have this problem and fixed it? Seems like something that could be fixed but no clue how.
Going to dealer tomorrow and figured I'd ask before going.
Sounds like grease might have found its way onto those rubber/felt seals inside and outside your windows. Wonder how the dealer will fix this issue without actually replacing those seals.
No grease here. But during the winter, white salt-like streaks would appear on the inside of my front windows after lowering/raising. I further confirmed that it was indeed salt after tasting it. How does salt get inside the door/window? Shouldn't do that, imo.
Cheers
Cheers
i guess ill say something, really annoys me.. i spend an hour cleaning every window perfectly.. put my window down to talk to the guard in my neighborhood and then its there clear as ever... gotta have door closed to clean too cause otherwise u miss the 1" at the bottom.
Sorry to see the same problem has been around for years and cuts across 3 different series.
The grease gets on a felt guide and can't be cleaned, the guide has to be replaced. My experience was that it was an involved job, and the dealers were reluctant to address it since it has the potential to return.
I gave up and just bought some more "Invisible Glass". Think of it as adding 'character'.
BD
BD
This problem is solvable; worked for me. Fold a microfiber over a wide blade putty knife and run it back and forth and up and down after jamming it down between seal and glass; move MF frequently (don't waste your time with a normal cloth). With window glass all the way down it's easier. Here's a plastic one:
BTW, more of my two cents: it's probably not necessarily grease from something Porsche did. The windows collect pollen and sap droplets other sticky stuff and then the seals wipe it off and collect the residue. Get a little moisture on there and the whole thing mucks up. Garaged? Sticky stuff can collect in just an hour of parking outdoors; especially in Spring. From my experience (third Porsche) this is an easy problem to fix. Do they EVER mention it in the manual; i.e. in the "how to clean the car" section? Do we have a "how to clean the car" section?
thank you!, will try today.. going to walmart now for the putty knife.. i have a metal one but i feel will inflict irreparable damage.
Does Porsche have any procedure for reporting things like this that they should fix in the next gen?
