Switchable Power Wire???
03-13-2010, 12:08 PM
can some one chime in please which color is the Switchable Power wire???
TIA
03-13-2010, 06:17 PM
03-13-2010, 11:23 PM
Your question is too vague. But if you want a new switched circuit, you can add one to one of the vacant fuse positions in row C of the fuse panel.
03-14-2010, 01:45 PM
Thanks that is what I was thinking about!!!
I am hardwiring my 9500 IX.
03-14-2010, 02:53 PM
Here's a photo of how I added a switched circuit to my Targa4S.
03-14-2010, 03:04 PM
Ken,
Where did you get the connector that pugs into a fuse spot?
Also, does it plug into two fuse spots?
TIA.
03-14-2010, 03:07 PM
03-14-2010, 03:13 PM
Quote:
Originally Posted by
Gleek48
Ken,
TIA.
I got mine at PEP Boys. It occupies one fuse slot.
03-14-2010, 04:32 PM
PoseurRennlist Member
If you go in from behind you won't have a connector sticking in the front of the fuse box. The fuse box can be simply removed from the firewall. Use a multimeter to locate a good wire for your purposes.
