PDK updates....
#77
Voila! - or at least french fries.
Thanks.
Although the Windows analogy is a bit off as every Win update has a KB number and explanation.
Thanks.
#78
ok...found it...
So this is what my Master Tech Jim McFarland said:
"It's NOT a P-TECH, recall or open claim issue. PAG/PCNA downloads the latest version of software in to our system, and when we hook it up to the car it either takes it (the download) or not. Think of it as an update you recieve for windows. Your system either had the latest version or not."
So my guess is; becase Porsche does not offer any cut off dates; if you have an earlier PDK, tell them *your dealer* to hook it up and see if it takes it.
Good luck.
(In this scenario, Dr. Kerns car was build in December of 08, for reference).
Good luck.
#79
My CS recently experienced the same problems as SeamusC4S with jerking at low revs.
When I was caught in slow moving traffic the car would slide easily up to second gear and when braking and the car was to change down the engine actually increased revs momentarily almost like a throttle blip but 1st gear was already engaged and the car would lurch forward.
I got around it by shifting to neutral each time I was slowing to avoid nudging someone in front.
When I took it to the dealer they said they did an software upgrade that had to do with the engine mapping but in particular with the PDK interface so this may be the "fabled" PDK upgrade.
#80
My wife has a new 09 Boxster with pdk. The upshifting is so smooth in auto, you would be hard pressed to even tell when the shifts occur. My 911 CS2 2009 pdk is not even close as far as the smoothness. In my car at slow speeds you can feel every upshift. Sometimes you get a clunking sound. The downshifts in sport mode 3 to 2 and 2 to 1 are the worst. Should I be expecting the same performance as the Boxster in a car that was almost 1/2 the price? My car was manufactured 7/08 and the Boxster was 1/09.
#81
I think you should have it checked out.
#82
It was one of the green launch cars and had about 100 miles on it. The report the dealer gave me was that there were only about 600 range one ignitions. Nothing above that. Does anyone no if the dme report will show if and how many times the car was launched? If so, where on the report can I find that information? The car now has about 2200 miles.
#83
Why has all the discussion on the rough downshifting gone silent? Where are those that infered they had the problem and got it fixed? Those of us still with the problem need evidence of a solution.
#84
They got "shouted down" by those claiming there was no update.
I took delivery of my May 31st, and the Dealer did all the software upgrades.
Buy your service manager lunch and have him run the latest "software" revisions, even if he claims that he doesn't know what they do!
#86
Mine is a Sep 08 build and works fine. My big worry is how to keep the dealer from doing any updates that will screw it up.
#87
Just curious. Red Horse, you say that yours is fine--Can you feel the pdk shifting in auto at lower speeds? Any noise at all? Do you get any jerking when in auto- sport mode and down shifting from 2 to 1? I ask because mine does this and my wife's Boxster with pdk is smooth as glass.
#88
#89
But, if there is really a "fix" for this, I certainly will want to get the "pdk update".
#90
I am usually in the same boat, but after this thread, I tested manually shifting from 2nd to 1st in Sport manual (at around 10 mph or less). I don't get any clunking, any noises, nada. My PDK shifts great in every mode, whether manual or auto. Sport Plus feels very hard on the transmission, so I've only used it once on the track.
