Brake Job -- parts needed
Poseur
Poseur
That's not factually true. All materials experience abrasion to some degree, some more than others, when shear forces are applied to the moving surface. The carbon fiber reinforced ceramic disc of the PCCBs does exhibit less wear over time compared to the steel variety, but it does wear, though not as noticeably.
Brake dust always primarily comes from the pads. Even with steel rotors, which are a lot tougher than the relatively soft pads, the abrasion is primarily in the pads, hence the dust. Generally speaking, the softer the pad the higher the coefficient of friction of the pad (more braking power), and the more wear and dust from the pad. The special compound on the PCCB pads is designed to provide optimum coefficient of friction when applied on the carbon fiber reinforced ceramic discs, which means they are of a tougher compound than standard pads, which means they wear less, which means they generate less dust.
http://www.europeancarweb.com/tech/0...kes/index.html
Fluid
Suggest you return the fluid in the picture
and get the blue fluid. You need to bleed the brakes every two
years and it is easier to bleed when the blue comes out.
The hardest part of doing the brakes is taking the tires off and
putting them on. Everything else is simple.
Paul
Paul
Poseur
Thanks for the fluid tip. I routinely pull wheels off the car so I have that part down. I have also heard some downsides to the blue fluid, in that it stains the reservoir. I've done quite a bit of brake work over the decades, and think I should be able to guesstimate when I'm into the new stuff.
I just bought new rear PCCB pads for my car. Dealer looked up part numbers for PCCB cars and IRON cars, and the part number for the pads was the same. Hence, the same pad. Had him double check because it sounded odd, but he said same pad.
Maybe Edgy or someone else who has PCCBs and have replaced their pads can chime in here.
But everything I've read on them indicate they are indeed of different compound and larger in size:
https://rennlist.com/forums/997-foru...ml#post5410310
https://rennlist.com/forums/997-gt2-...placement.html
That was my thought too. Until I spoke to Suncoast. And they looked up the same part number for both cars.
If you look on the Suncoast site, under "Replacement Parts" for GT3, the even mention that pads are for both PCCB and Iron brakes.
Poseur
When I first investigated getting PCCBs for my car I checked my local parts guy for the price of them,--for iron brakes, and for PCCBs. The price was about $100 more for the PCCB ones. I can't for a moment believe that the pads are the same part number for a 6 piston PCCB caliper vice a 4 piston caliper for the iron rotors,--they're of a completely different size.
If you think you're going to be going through brake pads a lot, you might want to start stocking up. The PCCB pads listed at $385 when I ordered mine from Sunset (and got them for $228) and locally they told me they are up to $404 now.
Edgy you should return that stuff. Either you or the car will be dead by the time you need new brake pads. Incidentally, I flushed with the blue stuff a couple of years ago. Doesn't appear to be stained. I will know for sure in a few weeks when I flush with the gold stuff.
Poseur
Thanks,--let me know about the blue stuff and if it has an affinity for staining the inside of the reservoir. I'm doing my very best to use my brakes,--but it will be awhile to get them down to replacement size. Routinely, I used to see significant wear on fronts vice rears first,--is that still the case with PCCB do you think, or does it matter?
