Tow Hook License Bracket
There are several tow hook license plate brackets, e.g., www.moweraxle.com and www.gominigo.com/NHLPB-main.html, and others. Which is the favorite?
I use the moweraxle kit once a year if you catch my drift.
It works great for this purpose,....easy on, easy off.
I keep it in my trunk along with a license plate just in case.
Poseur
I try to avoid encounters with 'the man' by not giving them an excuse to stop me in the first place. I simply mounted my mandatory front plate lower where I didn't have to drill into paint. If you don't have a center radiator then you can simply copy my plate placement.
Team Owner
I've been looking for one of these for my 996 as of late, too. I thought there was a Canadian guy that was selling something very similar to the "professional" ones for $30-40...anyone remember him?
It's not exactly a highly technical part, so I question if they're worth $70-90.
That may be true but I shudder to think what would happen if it broke off at speed and went cartwheeling over the top of the car. I'd rather have a quality product and the piece of mind.
Poseur
(I also put a ABS skid plate on the front to keep things from getting damaged up front)
It seems very well made and the plate backing is plastic and is lighter. The fasteners are all high quality. It costs $35. The vendor contact is: stumberger_r@msn.com.
More info on this THREAD.
I put 4 SS bolts through the roof of the center plug (black plastic filler-panel) and backed them up with good sized fender washers. To those studs I mounted a couple of gate hinges. On the hinge I drilled and tapped screw threads to mount a stock European plate mount. Any standard US state plate will fit that setup. As a bonus, it hangs down just below the front lip of the car, and sounds off should I get close to the ground with a steep dip. When I start to hear the edge of the plate holder, I know I'm close to doing damage to the nose of the car.
John
Poseur
I think it was from Performance Products.
Here you go:
http://www.automotion.com/product.as...Fid=4086#tab_a
You'll need to add some more holes and fasteners than what they send you.
Here you go:
Team Owner
The item you are referring to is this one:
