Need help with balance/shimmy/shake/???
Dear Abby,
First, thanks to kdurg for some insight.
I've had this problem since I bought my 07 997s used in November.
The car has a shimmy in the wheel between 45-65 mph.
I took it to Discount for a balance and the guys said the two drivers side wheels were out of round. They zero'd out, but were visibly out of round to him.
So, i took those two wheels into Wheels America to get fixed.
Wheels Am didnt say what was wrong with them, but said they were now fixed.
The shimmy is still there.
I talked to a racer today and he said that the problem is caused by one of three issues:
1. wheels/tires need balancing
2. wheels bent
3. radial run out with the tires.
Since I had 1 and 2 done (assuming Wheels Am really fixed them)
The problem is 45 - 65 mph.
I can see and feel the shimmy in the steering wheel, but I can also feel the shimmy in the pedal.
The shimmy is more obvious on certain roads (country roads).
I had the 20k service done at the stealer in Nov and they checked the alignment at that time.
Any suggestions?
Sincerely,
Shimmy and a Shake
2. wheels bent
Any suggestions?
Sincerely,
Shimmy and a Shake
I just had tires put on and the installer showed me one of my front wheels was slightly out of round as well. I do not feel any shimmy in the car.
When you say you can feel it in the pedal I suspect you may have a warped or out of round brake rotor.
problem solved now.....had them rebalanced and road forced one wheel which would not balance. When they were balanced 5 months ago, they did a static balance (weights in the center of the wheel). This time they did a dynamic balance (weights on both sides).
i probably didnt describe the pedal issue correctly....it was on the floor board, thus i felt it in the throttle and brake
i have the same problem and also went thru alignment, balancing etc and they told me i t was fine...onthe way home friday i thought i had carpal tunnel from the shimmying at 69 mph. i do have gt3 control arms with -2.3 degrees in front 0 toe but do not think that the alignment is teh issue
i'm going back next wk...
mk
mk
