softronic ecu flash
Man of Many Porsches
I've done GIAC for my previous cars.. but this one is one of the best noticeable power
even on an n/a engine you can really feel the difference..
they send you 2 files and you can do it yourself.. make sure your laptop has enough battery and your car battery is connected to a charger.. you can reflash from stock to tuned in 5 minutes..
I used Dan from Vivid Racing...
here's the softronic site
http://www.softronic.us/products.php
But I agree with the above post.. my dealer is mod friendly.. make sure you have good relationship with them...
Interesting considering there are no emails for the month of Jan. that have not been responed to. When did you send one???
It always amazes me that people make claims about "no warrantee issues". Let me warn you, if you kill the engine (which is very unlikely), the regional rep will show up at the dealer and attach a special computer that even the dealers don't have access to and it will show any modifications to the ECU. Even if they use Porsche files. At that point, your dealer is out of the loop for making warrantee decisions.
Also be wary of posters who have only 1 or 2 posts talking about a product.
1-so are you saying that you have an guarantee in writing that you stand behind that if something happens to the engine that is under Porsche warranty that you can flash the ECU back to stock and that Porsche can not tell that the ECU has been tampered with?
2- If something happens to the engine that is a result from the ECU being reprogrammed that Softronic will warranty the engine?
thanks! Mike
trying to understand this here...
thanks! Mike
thanks! Mike
2.First of all Softronic does and will not make any changes that will cause the engine to expire. I think an owner would be the likely candidate for this from a missed shift or tampering with the boost in a turbo etc. I can guarantee that the DME will be in the state that it was in the moment the car was built and started at the factory. I think the biggest problem is that most people do not understand or know what makes an DME work or how it is checked or programmed.
You can also ask a similar question on the PCA Technical site and I will answer also.
Best,
Scott Slauson
Hello, I used the form on your website. I can assure you that I have no reason to lie, or ax to grind. As a matter of fact, I was/am interested in your software based on the positive posts I have read here and on 6Speed.
I specifically asked you about costs for custom tuned software based on the existing modifications I have and plan on my 2006 C4S.
My apologies however I did not receive a question from you. We had problem with our server late Thursday and Friday if either of those days you had submitted it.
In any case please resubmit one and I will keep an eye out for it or you can call me now if you like.
Best,
Scott
This was seen with the Boxster 3.2 getting its final power boost before it was dropped for the 3.4 engine.
Do you recommend other changes, such as X51 headers, and/or PSE or aftermarket exhausts?
The stock and gains are listed at the Software section. The only car listed that I would suggest to get its full gain to 389hp is the 3.8s and that I would recommend X51 headers and mufflers or similar. This engine was at 376 with out these and added for additional breathing. All other listings are for a stock car without any other exhaust or intake mods.
I'm not a sponsor yet so I do not want to overstep my bounds and try and sell anything. I would like it if any other questions were asked in a email to me from the Panoroma Technical email listed in the back of the book or via the web site.
Thank You,
Scott Slauson
Unique Title
Does anyone else find it interesting that the satisfied user of this software only just signed up to Rennlist and all his posts are in this one thread touting the product? POSTING IN ALL CAPS doesn't help his credibility either.
He certainly could be a genuine, satisfied customer but often on Internet sites posters with this profile are likely to be shills.
I do not have this ecu flash but have done this type of thing to many motorcycles. I would tend to believe from working with ecu upgrades that the fuel curve is re-mapped and the ignition timing plus the fuel injector pulses.
I would love to do a ECU change for my car but I do a lot of track days and I am still not convinced that IF there was an engine issue with a burned piston or in the drive train that Porsche could not be able to examine the ECU and tell if it has been tampered with.
If I had a guarantee from a ECU re-flash company on this issue I would go for it. None of these companies will do this nor will they go into depth about what they changed on the ECU...seems a little wishy washy for me at this point with my new car.
marine (Scott) I drive a 2007 997S with the only mod as Fabspeed max-flo mufflers. I also drive a Tip due to not having a left leg.
1-So is there anything in your software that makes the Tip hold the gears longer and shift better in drive mode for street use?
2-Is there anything in your software that allows the Tip to be downshifted faster and at a higher mph and rpm in manual mode?
3-Does your software change anything in the cars sport mode with the throttle sensativity?
thanks! Mike
