sunroof vibration, noise, thumping
I searched on this topic and found a few threads, but nothing specific to my problem. maybe its normal, wonder if any of you experience this....
windows up, traveling between 35-55 mph and suddenly my ears go numb from the thumping harmonics of the air inside the car. I am guessing it has to do with the vibration of the headliner as air passes between it and the roof at this speed range. I played around with it a little, but nothing really seems to help.
is this something i just have to live with or should i take it in and have the dealership try to fix it? any advice would be helpful thanks.
It's a 'feature' when you have a well made, well sealed car.
A certain speeds you get pressure wave harmonics with the air passing over the open sunroof.
As has been mentioned, cracking a window will stop the effect.
Or you could buy one of those 'cool' plastic sunroof defelectors from the 80's, ,and fix that to the top of your 997.......
errrrr. Maybe not!
errrrr. Maybe not!
errrrr. Maybe not!
errrrr. Maybe not!
Always thought, such a well made car, how did they screw up the sunroof so badly. I like your explanation better.
The Penguin King
Originally Posted by MJones
You have an '05?
They changed the defector in '06 to a different design configuration that helps solve the problem
I've had this sensation in past cars but I'm guessing the air deflector works a bit better in my 4S because I can drive with just the sunroof open with no 'whooping.'
and speaking of german engineering and airtight cars....
The text for those younger members:
It floats.
The way our body is built, we'd be surprised if it didn't. The sheet of flat steel that goes underneath every Volkswagen keeps out water, as well as dirt and salt and other nasty things that can eat away at the underside of a car. So it's watertight at the bottom. And everybody knows it's easier to shut the door on a Volkswagen after you've rolled down the window a little.
That proves it's practically airtight on top. If it was a boat, we could call it the Water Bug. But it's not a boat, it's a car.
And, like Mary Jo Kopechne, it's only 99 and 44/100 percent pure. So it won't stay afloat forever. Just long enough. Poor Teddy. If he'd been smart enough to buy a Volkswagen, he never would have gotten into hot water.
It floats.
You have an '05?
I am picking up an '07 this week. Thrilled to hear they fixed it.
I doubt if the issue is completely fixed, as Dr Drilz said it involves laws of physics. My Benz does the same thing. Just crack a side window you won't notice the additional noise.
I have had this problem on my previous car
I would just adjust the position of the roof (slightly) either open it more or close it a bit and that would take care of the noise.
I just ordered the 06' deflector and install kit. $103. for the deflector, and $45. for the requiste install kit all from Sunset Porsche. Approx. 1 week for delivery. Sunset says the 06' part is now listed as the replacement part for the 05' car if you have to repair of replace it.
I'm sure I could have bought it here locally and probably for the same amount when you factor shipping vs. tax, but I just can't suport the idiocy that emulates from the dealers here in Lala land.....
