Fog Lights as Daytime Running Lights?
No sport Chrono pkg, but I would like to have the fogs wired to be able to turn on as DTRL's Possible or way too much work?
you definetely need the schems. once you find the relay that drives the fogs and cut the power source (usually comes from the head lights) and then you splice a wire from a switched v source (usually cig lig works best) to drive the fogs relay.
voila DD using fogs.
this is exactly what i did to my Z.
Poseur
You can have the daylight running lights on the car which, I believe, are not the Bi-Zenons. They're rigged to go on for me with my Key #2. The dealership should be able to configure that for you in a few minutes, since you have no Sports Chrono.
I'll ask next week wehn I get the damn trunk key reprogrammed to 700ms. That thing is driving me crazy!
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
[QUOTE=OCBen]Why bother?
Small frontal area, hard to see car in a region with some of the least attentive drivers I've seen. Better visability by others,
and I don' want the taillights and side lights on. Personal choice.
the front fog lights areBi-Xenon ( I think it's a good thing) I use them for daytime driving on a regular basis. The rear fog lights are not they're the same light as brake light. Not to get off the subject but I'm havib a problem with the rear fog lights. The right fog light does not brightin when I turn them on(checked and doubled checked the bulbs. If anyone has an idea on what it might be let me know.
Originally Posted by QKENUFF
Thanks,
Poseur
USA cars only have an active rear fog on the driver's side.
Ben,--in Japan they like to turn off their headlights at intersections while awaiting the green. (power savings!) lol
Sorry it is a halogen H8 . The rear fog is just one light but it's the same as the brake light P21/4w The brake light brightens when you step on the brake . I assume the foglight will when you pull the switch . My problem Is that only one side gets bright and I am positive it's not the bulb.
