PASM or LSD in 997C2S
how does PASM differ from LSD when it driving
1) normally on street and
2) at the limits on track?
can the mechanical LSD fail (ie breakdown) under normal street drving conditions?
The two have no connection whatsoever. PASM is an active suspension system. LSD is a mechanical traction control system (not available on 997C2S in US). Yes an LSD (like everything else in life) can fail under normal everyday conditions.
Ironman 140.6
PSM is yaw control and will manipulate throttle and brakes to prevent what it reads as loss of control within its parameters. It is standard equipment. LSD is traction control at the rear, minimizing wheel spin by shifting power between drive wheels as needed. It is optional in Europe. PASM is active suspension as indicated above. Anything that can break will.
Moderator
I've done a few searches on this a while ago and found some good information. It was my recollection that Porsche did not include LSD on the 997 because (simple terms) it wasn't needed due to the way the drive train is set up, the massive amount of grip at the rear, and PSM. I don't know that I've heard of anyone with a 997S "needing" it on street or at DE levels. If you are building a race car from your 997 then it's probably a very easy thing to add. This was my layperson recollection - I'm sure the technically adept and racer types can give more accuracy and detail.
It is interesting to me that it is offered on the TT. I'm not a mechanical engineer, but it would seem less necessary in an AWD car.
