No Front Plate Ticket
Old 01-08-2007, 01:15 PM
JDC48
JDC48's Avatar
Default No Front Plate Ticket
Can I get a ticket for not having a front plate if my car is registered in NY but I am in New Jersey.
Old 01-08-2007, 01:41 PM
clif
clif's Avatar
they are reciprocal, larry the mower guy, (real name) makes a front plate holder out of a tow hook so it is removable.
Old 01-08-2007, 01:57 PM
RAKLAW
RAKLAW's Avatar
I ran around for a while without one, but driving through all the villages in Westchester with the full on hack with PSE it was not worth the aggravation of getting pullled over with probable cause (No front plate). I put on the "lawn mower" gizzmo and now I dont even think about it. Actually I think it looks cool, off to the side like that.
Old 01-08-2007, 02:02 PM
Edgy01
Poseur
Edgy01's Avatar
Some time post a shot of the front end with that mount. I have a different design which also spares the drill-through-paint routine. Not good for tiptronic and X51 users however,--it goes over the central air intake.
Old 01-08-2007, 03:08 PM
jnx
jnx's Avatar
Can you post a pic, or a link to the mower site? Thanks
Old 01-08-2007, 03:17 PM
Stephenkng
Stephenkng's Avatar
http://www.moweraxle.com/index.html
Here is the link. The price is $84.95
Old 01-08-2007, 04:49 PM
Edgy01
Poseur
Edgy01's Avatar
Looked at it,--don't care for the offset look. Nice components, but it looks too asymetrical to me.
Old 01-08-2007, 04:55 PM
Stephenkng
Stephenkng's Avatar
I will probably get one if you get a ticket. Knok on wook haven't get it yet. I think still better drill a couple of holes on the bumper.
Old 01-08-2007, 04:59 PM
Sharptt
Sharptt's Avatar
It's a clever solution but I think it looks terrible off to the side. It upsets the entire visual balance and symmetry of the car. There has to be a better answetr to the front plate dilemma out there.
Old 01-08-2007, 05:13 PM
Edgy01
Poseur
Edgy01's Avatar
Rather than drill holes in the bumper I drilled 4 holes in the top area of the center grill filler panel, and put in 4 bolts to which I installed a couple of hinge assemblies. To that I attached the plate mount,--which is what the plate is mounted to. When removed you don't see a thing. The only impact is to those with a Tip and/or an X51 package which used the center for cooling.
Old 01-08-2007, 07:43 PM
diverdan
diverdan's Avatar
I have Larry's kit. I haven't installed it yet, due to the fact that California is a little slow sending me my license plates. I will say the kit is well made and cleanly implemented.
Old 01-08-2007, 08:24 PM
larrytrk
larrytrk's Avatar
Larry's kit , with plate mounted, has been in my trunk for 10 months as a backup. Don't want to jinks it ,but, so far so good!!
Old 01-08-2007, 09:40 PM
jnx
jnx's Avatar
Thanks for the link, It looks well constructed and a great idea, just not sure I care for the look.
Old 01-08-2007, 10:02 PM
Mike R.
Mike R.'s Avatar
JDC48 - If your car is principally garaged in NJ, but registered in NY, you run the risk of bigger problems if your car is involved in an accident. The vast majority of cops in NJ will not pull you over for no front plate, but it certainly gives them a reason if they want to.
Very truly yours,
Debbie Downer
Old 01-09-2007, 12:03 AM
Edgy01
Poseur
Edgy01's Avatar
Here's a shot of my work in progress on a no drill front plate arrangement. Will provide updates as time permits.
Four stainless steel bolts are secured in the center filler panel to which to mount the plate adapter which is under construction. I'm presently using a pair of hinges to mount the plate temporarily.
Quick Reply: No Front Plate Ticket
