Detailing
Old 06-19-2006, 03:46 PM
robbonds
robbonds's Avatar
Default Detailing
novice detailer here - should i buy and use this kit? other suggestions?
thanks
ZAINO
For the ultimate in show car appearance and total protection, here are the Zaino products that you'll need to make it happen. Included in the Zaino Show Car Kit are everything pictured including the following:
ZFX™ Flash Cure Accelerator Additive
Z-2 PRO™ Show Car Polish for Clear Coated Car Finishes
Z-5 PRO™ Show Car Polish for Swirl Marks and Fine Scratches
Z-6™ Ultra Clean Gloss Enhancer Spray
Z-7™ Show Car Wash
Z-18™ ClayBar
Zaino Metallic Silver Decal
& TWO Zaino Custom Polish Applicator for FREE!
$85
Old 06-19-2006, 04:01 PM
robbonds
robbonds's Avatar
or this?
Kit Contents:
Sonus SFX Ultra-Fine Detailing Clay (3 oz. bar)
Sonus Glyde Clay Lubricant (16 oz.)
Sonus SFX-1 Restore Polish (8 oz.)
Sonus SFX-2 Enhance Polish (8 oz.)
Sonus Detailing Spritz (8 oz.)
Sonus Der Wunder Applicators (2)
Sonus SFX Professional Applicator (1)
Sonus Der Wunder Polishing Towels (2)
Sonus Der Wunder Buffing Towels (2)
Klasse All-In-One Sealant (10 oz.)
P21S Carnauba Wax (6.2 oz.).
$125
Old 06-19-2006, 04:09 PM
ohsixx
ohsixx's Avatar
Zaino has some good products. The Z5 PRO is new and supposelly very good.
I still use Z9 Leather Cleaner and Z10 Leather In A Bottle. Z9 and 10 is the best stuff I have ever used on leather.
I begin using REJEX which is a sealant about a year ago on the exterior paint, glass, and wheels. It is the perfect product if you don't want to kill yourself detailing.
Old 06-19-2006, 04:12 PM
Deanski
Deanski's Avatar
Default Zaino
See my post in the other thread.
Zaino does make any finish look outstanding, but it does take time and proper finish care. It WILL highlight defects (marring,spiderwebbing, swirls) if these are not removed first. If you have a finish which is free from swirls, Zaino will make it look very glossy, lasts a long tim, is very slick.
The new Z5-Pro does hide better, but not as good as a glaze. Glaze uses oils/clay to fill minor defects. From a glaze you can use a wax. Problem using a glaze with Zaino is you will wash-out most of the effects/filling prior to Zaino. Zaino requires a fresh, clean, oil-free/wax free finish. A high alkaline wash will remove oils/waxes. Then Zaino will bond to the paint.
With ZFX, you can coat the finish 3 times in one sesion. It goes on VERY VERY THIN!! To the point where it's hard to see where you applied it. If you apply too much, it streaks because the top layer cures first, but the lower layer of the heavy amount is still wet and will when wiped off, it beings to streak. Then you know you have too much on. One ounce will do the entire car and still have some left. If it streaks, mix up Z7 wash with distilld water and spray the area and wipe off.
Best effects and ease of use, spray the finish with Z6 or Z8 before and after each coat. Spray your applicator pad lightly to help Zaino flow on the finish. It will be very glossy/wet looking once done. After Z5-Pro and I'm happy, I switch to Z2-Pro which has higher optical properties and is very clear.
I do Z5-Pro one day, next day I do Z2-Pro. This lets Zaino cure/bond with the paint the longer it sits w/o disturbing it. Then watch the water bead and see how easy washing becomes after that!
Use it on wheels! Very easy to remove brake dust afterwards. It's one of the sealants that can stand the heat from brakes.
You can always call Sal Zaino and ask him directly. He will assist you in every aspect in using Zaino.
Regards,
Deanski,
Dr. Shine
Old 06-19-2006, 04:19 PM
Deanski
Deanski's Avatar
Default Sonus
That kit sounds good exept I'd not go with the #1 as it's the most abrasive. I'd get #2 and #3 from Sonus as they are very mild. The Klasse sealant is fool-proof. AIO is a cleaner/sealant and does a nice job. The Sonus Ultra-Fine clay works very well, the towels are top notch as well.
Some of us in the field will use AIO as a pre-cleaning before Zaino. The pre-VOC Klasse AIO is what works best for prep before Zaino. Or, just leave the AIO on and use the Klasse Gloss sealant and then you could even top it with a wax if you want deeper look. If your finish is silver, one wax I will always go to is P21S. That makes silver metallic POP!
It all depends on what you are looking for in detailing your finish. How much time etc.
Regards,
Deanski
Old 06-19-2006, 04:39 PM
robbonds
robbonds's Avatar
im just more confused...zaino, rejex, sonus.......
Old 06-19-2006, 04:45 PM
Deanski
Deanski's Avatar
I'd shy away from Rejex. It's look has a "Saran-Wrap" look to it.
Zaino works well... It takes a bit more time for first time users. Sonus kit looks good, just as I siad, I'd substitute a finer polish for Sonus #1. I'm sure your finish is pretty damn good, so I'd ask to swap Sonus 1 for Sonus 3.
How much time and will you be doing this in the sun?
Dr. Shine
Old 06-19-2006, 04:46 PM
robbonds
robbonds's Avatar
ill wash outside - the rest in my garage...i dont mind spending 2-3hrs
Old 06-19-2006, 04:47 PM
robbonds
robbonds's Avatar
also - i live florida - zillions of love bugs - i mean zillions
Old 06-19-2006, 04:53 PM
Deanski
Deanski's Avatar
Default Bugs
EEK! I HATE those things!
I'd stay with a sealant for ease of removal from the impact. A QD spray may not remove them as easy. In fact, once baked in the sun, they really become difficult. Then it's up to washing to get those off or at least loosen them and make them softer for a QD to remove, but you'll be folding the towels quite often so you do not drag what remains from them back over the paint creating marring.
Dr. Shine
Old 06-19-2006, 05:19 PM
robbonds
robbonds's Avatar
can i rejex on top of zaino ?
Old 06-19-2006, 05:32 PM
ohsixx
ohsixx's Avatar
Hey Rob: This is a good place for car care info. You don't have to sign up; just read. They eventually cover it all.
http://forums.corvetteforum.com/zeroforum?id=10
Old 06-19-2006, 05:51 PM
Deanski
Deanski's Avatar
No don't do that! You'll kill all the effects of Zaino AND you're just adding another sealant on top of a superior sealant for no reason except to get that plastic-wrap look to it.
Just leave Zaino alone! You just need to maintain with Z6 or Z8 spray, that's all.
Dr. Shine
Old 06-20-2006, 01:40 PM
robbonds
robbonds's Avatar
Thanks Dr. shine - heres what im about to order..
1. zaino kit
Z-7™ Show Car Wash
Z-18™ ClayBar
2. zaino tire cleaner
3. zaino z-8 finale
4. flitz chrome cleaner
5. detailers paradise towel from pakshak
6. wash mitt from pakshak
that cover everything?
Old 06-20-2006, 02:25 PM
wross996tt
wross996tt's Avatar
I would add the following:
1. Poorboys S&W and Wheel Sealant
2. Zaino's leather conditioner
3. Aerospace 303 (for leather and rubber that gets sun)
4. RaggTopp Cleaner and Protectant
5. Eventually you need a PC.
Quick Reply: Detailing
