Curious...just realized that the 993 C4 (which I had) was the same width in rear as the C2, but the S was wider (whether 2 or 4). In contrast, the 997 CS is the same width as the C, but the C4 or C4S are wider. I guess width is pure design element, not functional difference.
Geez, I wish I knew what it was but I have to believe there's a cold and logical functional engineered reason for the additional width.
You could easily argue that with awd you can get away with NARROWER tires not wider ones as the awd should provide you with better traction. Look back at the 993 and 996 C4 and there was no difference in width. I don't believe that tire technology and Porsche's awd engineering skills have gone into reverse all of a sudden. What I suspect you're seeing is the amazing grip that marketing is exerting on Porsche these days...
-The 997 GT3 is apparently based on the C4 platform but with the narrow body.
-Wider rear tires aren't necessary on an AWD car; in fact, the opposite would be true with power being distributed more evenly and weight being a bit more balanced F/R.
-Even given the above, wider rear tires will fit within the standard narrow body (as on the 997 GT3).
-The wider body is so very subtle, and doesn't have any other design elements separating it from the narrow body.
So I don't get it either, and not sure why it would be a marketing thing. My original thought was that they were just introducing the wider body with the C4/C4S, which would eventually be available on 2WD models.
Just a guess, but maybe the wider body is needed for the front drive train, thus the C4s and turbo share the same body. ??
Not sure why the rear fenders would need to be wider for the front drivetrain, especially since the C4/C4S rear wheels fill out the wider fenders with deeper dish and spacers. Plus, there were narrow-bodied 996s with AWD.
I'm not questioning the logic or marketing reason. When shopping for the car, I looked at the tire dimensions at c2 and c4. don't know Porsche's reason.
From the website:
c4 = 235/40 ZR 18 front, 295/35 ZR 18 rear
c2 = 235/40 ZR 18 front, 265/40 ZR 18 rear
Widening the track with the same wheelbase has inherant cornering benefits. That of itself requires wider bodywork.
Apart from that, lower and wider have always had stylistic impact. The rear view, or'hips" of the car also seems to have an anthropomorphic, subliminal impact on perception of styling. What was the last tall, skinny car you liked?
In my opinion, the wide rear tires / track points to the fact that Porsche (unlike Audi and Subaru) designed the AWD cars to have a solid rear-wheel bias and act more like the RWD cars... the inherent delay in moving the torque split to the front (due to the viscous interaxle diff) allows the C4S to actually yaw like a RWD vehicle. In my experience, when the rear gets loose, the delay to get sufficient power to the front to overcome the power oversteer is just long enough to make it fun. <g>
Now, with the electronically controlled interaxle diff in the new Turbo, things will be very different in terms of total capabilities... however, I'll assume that Porsche still intends the 997 Turbo to act like a RWD car as much as possible.
I drove a buddies highly-modded Audi S4, and it was basically impossible to get the tail out under acceleration - and his car sports over 400hp. I can do this in the stock C4S all day long.
don,
When you make the rear tires big relative to the front, you make the car understeer. That was Porsche's intention, since they want you to crash looking forward at what you are going to hit, rather than backward. If Porsche wanted more tail out attitude, they would keep the rear tires skinny.
With different driving techniques, you can make almost anything get the tail out. In most cars, acceleration out of a corner shfts weight to the rear and also causes understeer.
Are you referencing low speed acceleration and turning to get the tail out? At track speeds, I'm not sure that works. The tail comes out under trail braking. At least on my X50 AS
