Power Window Question
Old Apr 18, 2006 | 11:29 AM
icruze's Avatar
icruze
Default Power Window Question
The driver's side window has the one touch up and down feature. The passenger side window also goes down with one touch. However, the passenger side window does not go up with one touch until you get to about 1/2 of the way up.
Do all of you have the same experience or is it a problem with my car's window control?
Old Apr 18, 2006 | 11:34 AM
rotthaus's Avatar
rotthaus
Mine are the same way.
Old Apr 18, 2006 | 11:37 AM
PDQ PDK CAYMAN S's Avatar
PDQ PDK CAYMAN S
If you are really quick touching the right button it will go up. I am never that quick.
Old Apr 18, 2006 | 11:38 AM
OCBen's Avatar
OCBen
See here:
https://rennlist.com/forums/showthre...ghlight=window
Old Apr 18, 2006 | 03:00 PM
Matt(inMA)'s Avatar
Matt(inMA)
Not in MA anymore
It's documented right in the manual - that's how it's supposed to work.
Matt
Old Apr 18, 2006 | 03:32 PM
Riad's Avatar
Riad
Chandler!
Matt
Spoken like a true Microsoft representative.
Old Apr 18, 2006 | 04:44 PM
Matt(inMA)'s Avatar
Matt(inMA)
Not in MA anymore
OUCH!!
Old Apr 18, 2006 | 05:30 PM
M A Z N G's Avatar
M A Z N G
Originally Posted by OCBen
OCBen... Don't know you personally, but you my friend are the true master of all searches. I don't think I have seen one post where you have not replied with a link somewhere in the thread, when called for of course. It makes following up so much easier... Thank you!
The forum is lucky to have you.
Old Apr 18, 2006 | 06:03 PM
OCBen's Avatar
OCBen
Geeze, I was bracing for a sarcastic insult there. That's lately the type of comments I get. Thanks for the compliments.
My, what a pleasant surprise - someone actually appreciates how linked threads help tie the knowledge we share and learn together, and makes it easier to follow the "thread" of thought in a particular area of concern.
Ideally we would all do an initial search to see if the topic has been discussed before, that way we can keep all relevant discussions in a "logbook" of sorts which should make for an enjoyable read. But that's not gonna happen, realistically speaking.
I've been here a little over a year now and I'm young enough not to be suffering from dementia where I can't remember most of what's been discussed in that time, well for sure recently discussed. And so I go about and do a quick search to retrieve the relevant threads.
The key to searching is using the right "key" word. For example, in this thread about power window operation I remembered the topic but not the exact wording of the thread title. But I was absolutely certain the key word "window" was in it. And so I used "window" as my search word and - voila! - just like that it popped out, along with several other non-relevant threads. But it's easy to weed those out once you've narrowed it down and know what you're looking for.
Old Apr 21, 2006 | 02:41 AM
jfraser's Avatar
jfraser
Is it just the coupe that has this 'feature' or does the cab also have the one touch after half way on the passenger window?
Old Apr 27, 2006 | 12:21 AM
tgibson1's Avatar
tgibson1
IN my 997s cab both windows function with one touch both up and down
Old Apr 27, 2006 | 01:25 AM
jfraser's Avatar
jfraser
Thanks....I found out that this is a coupe only 'feature'
