OK Really dumb question... closing the hood (trunk)
wow, I'm really embarassed to ask this one but here goes LOL! When closing the (front) hood, do you just slam it shut? I opened mine for the first time yesterday and went to close it like you normally would any hood. However, it did not "latch" close. So, I just pushed down and it seemed to click shut.
A few minutes ago I went into the garage to take the garbage out and as soon as I got in looked over at the car and the hood popped!! (just as it would if you hit the button). Should I call a priest or what!! That would not be good to happen while i'm driving. So, if it should be shut by just dropping it, then I most have something mis-aligned. If you are supposed to just lower it and push it sealed, then how the hell did it un-latch itself!
They do not shut by dropping them. You need to push to latch after you drop it. I always used to push on the badge and later maybe here or somewhere heard that is not good that you can break the badge. Otherwise push just in front of the badge to latch (click) it shut.
I have noticed that when carrying the key on the new 997 it is extremely easy to hit the hood button especially when key is in your pocket. More than likely that is what happened to you.
The correct way to close the hood is to press in the area above the latch (between the crest and edge of the hood).
It is NOT advised to press upon the crest since the hood is aluminum and there is no support beneath it.
Why your hood poped open....if it was truly shut...
Check with your dealer, rhe front control unit may need replacing
The hood is aluminum and easily dented if slammed. If your cargo sticks up too far, it can bang a dent from the inside. Porsche recommends closing it by lowering it gently until the safety latch engages and then pressing down until the main latch grabs.
There were problems reported with the hood mysteriously unlatching by itself in early production. There should be some threads about this issue. It is also really easy to hit the wrong button on the remote. The ergonomic magicians that designed the key made the trunk button larger than the door button.
From the manual:
Closing luggage compartment lid and engine compartment lid
• Lower the lid and close it.
• Push the lid closed with the palm of your hand in the area of the lock.
Check that the lid has correctly engaged in the lock.
If you're not sure where exactly to push, lift the trunk lid and sight from the side of the lid the area directly over the u-shaped bracket that gets captured by the latch. Once you know where it is, you'll know from here on out where exactly to push.
If you're like me you won't want to leave your fingerprints on the hood. That's why I keep a mf towel in the door compartment under the armrest - for opening the gas cap lid and for closing the trunk lid. I also keep one hanging in the garage for when I need to close the trunk while in the garage.
You might find these threads of interest:
https://rennlist.com/forums/showthre...ght=hood+latch
OMG! you're too much ben!
UPDATE!!! Correct me if I'm wrong, this is something I heard.
The 996 was fine to close by pressing the badge to click it shut.
The 997 is different and you should not press the badge to click it shut.
On the 997 you should press the outer 3/4 inch of the trunk edge with spread thumb and forefinger to click it shut.
