Regular Gas Use?
Old Oct 13, 2024 | 10:26 AM
Vicbastige's Avatar
Vicbastige
Default Regular Gas Use?
Only able to get 87 in my area for the near-term. I think I know the answer, but I'll still ask: How bad of an idea is it to use the 87 with an octane boost additive?
Old Oct 13, 2024 | 11:10 AM
Tupper's Avatar
Tupper
Don’t do it!
Why do you only have 87 gas? Are you sure there are no options? That’s strange…
Old Oct 13, 2024 | 11:20 AM
joe 997's Avatar
joe 997
He probably lives in Florida. 87 is ok simply don't drive aggressively.
Old Oct 13, 2024 | 11:42 AM
Vicbastige's Avatar
Vicbastige
Hurricane Milton. First world problems given what many are struggling with to be sure. For those not in Florida, they prioritize fuel delivery quantities post hurricanes to simplify and speed up deliveries meaning most if not all pumps in a given area will likely be 87 only until supply chains normalizes. I was out of country and couldnt fill up with 93 before the storm. I'll just keep the car up and wait for 93 to return.
Old Oct 13, 2024 | 11:45 AM
Richard_Wallace's Avatar
Richard_Wallace
Fill up with 87 and buy some octane boost from your local auto parts store. You can then effectively make it 91 or 93 depending on the mixture/ratio. Not the most ideal situation, but can be done.
Old Oct 13, 2024 | 11:51 AM
CurryPuff's Avatar
CurryPuff
Octane booster is a great idea and I hope you didn't have any damage with Milton!
Aren't most cars turbo'd these days, requiring at least 89?
JRBucks's Avatar
JRBucks
Go on Sunoco's website and look to see what local stations carry their 98 & 100 octane. I know it'll be expensive but a lot cheaper than the problems detonation can cause. Also try VP's site.
Old Oct 13, 2024 | 02:15 PM
tna3's Avatar
tna3
Octane boost could be more harmful actually. Just put 87 and drive conservative. Let the ECU take care of the adjustment.
Old Oct 13, 2024 | 02:29 PM
ipse dixit's Avatar
ipse dixit
You're fine.
The engine will automatically adjust for the octane to prevent knocking.
Old Oct 13, 2024 | 02:37 PM
detansinn's Avatar
detansinn
ECU will adjust. When things settle down, take it in to service and they'll reset ECU and the anti-knock training -- you'll get your power back.
Old Oct 13, 2024 | 02:42 PM
Quadcammer's Avatar
Quadcammer
Run 87 and avoid high load situations. Most octane booster in the auto parts stores does essentially nothing...i.e. from 87 to 87.2
Old Oct 13, 2024 | 02:57 PM
Daytona67's Avatar
Daytona67
I'm in a Hurricane Milton affected area so I filled my 992 with premium pre-storm. My wife doesn't plan ahead so she got 87 octane post-storm for her MB.
Old Oct 13, 2024 | 03:15 PM
Angryinch's Avatar
Angryinch
Boostane works.
but if you cruise around and stay out of the boost, regular should be fine. Just don’t load the engine up heavy.
Old Oct 13, 2024 | 03:27 PM
Kobiejohn's Avatar
Kobiejohn
I also use Boostane at every fill up. Not sure the long term effects but 91 is the highest in Ak, I’ve read it can make your injectors (I think) turn orange.
Old Oct 13, 2024 | 03:58 PM
Hunky's Avatar
Hunky
What about 3 or 4 gallons per tank of E85?
