I have Satellite Radio in my 997 C4S Cab!
#241
Originally Posted by lockie
Congratulations Adam for your great work and Posts.. I was away for the weekend and feel like the Eagle landed and I missed it. I am so impressed with this forum I will have to become a member. It is such a nice feeling to pioneer something....(without a dealer) and be successful.
......If I can't upgrade my 2.1A to 2.1B I will have for sale all the parts for a XM sat radio for a 997 without the CD changer.......I really hope It doesn't come down to that....anyhow it appears that this is now a possibility for those with the 2.1B software.......I will continue to try to get mine working and if you have 2.1A stay tuned.........Again great work Adam!!! and thanks for your help so far.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Have you tried moving your antenna, or is the problem with the 2.1A PCM software?
#242
1080-can you scan the instruction sheets that came with the parts and email or post them. I believe that I and many others possess the mechanical skills to do the install-but would like to see if the wiring info is within my expertise-thanks-Bill
#244
Originally Posted by ltc
FWIW, I have some extra cables that were not used for the install and I took one apart. There is no way to cut and solder a new connector without having those connectors posted by LTC. In other words, you cant shorten the cables without new ends. Those things are crimped perfectly with a heavy rubber shield under the plastic part. Very well made I might add. In theory with the new connector ends and crimp tool and micro soldering iron (I would need to see the actual connector to see how the wire attaches) the cables could be shortened.
But.... is it worth it? For like $20 bucks or so maybe to clean it up. But I got a feeling the crimp tool is probably $50 - $75.00. The SAT works perfectly. I can't see the wires. There is no discernable signal loss.
There is DEFINITELY no way to shorten those cables without new ends and a crimp tool. You could cut the coax in the middle and solder and heat shrink, but THAT will cause signal loss for sure.
#245
Super Moderator
Needs More Cowbell
Needs More Cowbell
You can download the 40pg .pdf catalog here:
http://www.hubersuhner.com/hs-meta-d...arc-cat_en.pdf
In it there are descriptions on tools (crimpers and strippers) as well as applications/color coding.
You can contact them directly for samples/parts/distributors/questions:
19 Thompson Drive
Essex VT 05452 (USA)
Phone: +1 802 878 0555
Fax: +1 802 878 9880
E-Mail: info.us@hubersuhner.com
Website: www.hubersuhnerinc.com
Vermont Headquarter & Main Sales
Chicago Sales Office
Phone: +1 630 250 0100
Fax: +1 630 250 0460
19 Thompson Drive
#246
Super Moderator
Needs More Cowbell
Needs More Cowbell
Then again, what do I know?......I design tie wraps for a living.
#247
1080i,
Was wondering if the xm/sirrius kit contained all the parts needed (im looking at the part no 955.044.900.37 for xm without cd changer) or did we need to order all the parts listed on the tech sheet
posted earlier in the thread.
~Erik
~Erik
#249
I feel, in all this, that a disclaimer is in order. After all, the lawyer in me requires it.
I AM NOT AN EXPERT. My results worked. Your results may vary. Remember, some people had problems with this. I am not your tech support connection, but I will respond to questions until I get sick of responding and move on with life.
I do not work for PAG. I do not condone tinkering with your $100,000 car. Proceed at your own risk. Handle with care. Get it?
Seriously, remember that some people are having problems. I suggest that you be sure you have PCM 2.1B but I am not sure that it's required. So, that's all I have to say. If you blow up your ride or do something you regret, its not my fault.
#250
Thanks I have given that to my dealer and will be seeing him Monday.
I will also be trying the Antenna positioning again as well.
I got a email however indicating that one dealer advised that a Update to 2.1B is not possible.
I can't imagine Porsche issuing this bulletin and it not being possible. I've got over $2,000 invested so far and I'm going to find a way..
#251
Well, it obviously doesn't make sense to buy crimping tools for a one time application. The better advice, and I'm surprised it hasn't been stated yet, is to take your car to one of those car audio shops that specialize in SAT installations and pay a tech there to clean up the connections for you. Of course a suggestion like this would not be expected of a tie-wrap maker.
#252
You guys are killing me - the paristic loss by the extra meter or two of cable is minimal and less intrusive to the signal then warrants mention - since it's not even a cosmetic issue then why not leave the cable as is?
The install is a success - thanks to everyone who paved the way for us others - hope to have mine installed soon.
Cheers to everyone
Cheers to everyone
#254
CONGRATS 1080I
On a job well done and the pics are fantastic with details on how you proceeded to do this.
As for the cables, not to worry. Isn't one a fiber? No need to touch, if it works and it works well, leave it the hell alone!
As soon as my car goes PLPROD, I'll order a kit for one with CD changer.
Thanks guys for all you hard work!
Deanski
Deanski
#255
1080I - impressive. Question: with this install, do you happen to get an AUX in? Like for an iPod or other mp3 player?
If not, do you know a solution for AUX in?
Thanks!
Thanks!
