997 Fire Extinguisher mounts
Anybody have one yet? They are required for DE here and I may end up fabricating one from Stainless tubing or aluminum stock. Would there be any interest in these or are they available somewhere my garage doesn't know about?
Try Sunset Imports http://www.e-partssales.com/
or SunCoast Porsche http://www.sunsetporsche.com/porscheatcost.php
or Carnewal http://www.carnewal-europe.com/main.htm]
I'm interested Gary...I've been looking and have not had any luck. I called CDOC, Suncoast, my dealer (for the OEM) The Racers Group and checked the links DD694 posted...No luck
I've contacted both Safecraft Equipment and Brey-Krause. Reportedly, B-K is now working on a bolt-on seat mount bracket for the 997. Their 996 seat mount will not fit the 997. In another vehicle, I have a Safecraft billet head extinguisher and Safecraft billet quick-release bracket mounted to a B-K seat mount. I find the products to be nicely machined and highly functional, although passengers expressed concern with the extinguisher being positioned below their legs. I've since moved the mount to the driver's seat.
Safecraft does have other "universal" mounts available.
It is made from 1/8" aluminum diamond plate and three 5/16" SS bolts.. thats it. It goes in/out in about 3 minutes with the removal ot the two front seat mount bolts. Let me know if you want to see pics...
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Originally Posted by mds
Gary, I'd like to see pics.
This is the assembled unit ready to go in.
![](http://www.icer.net/Exting_top_out.jpg)
Bottom of the unit, you can see I ground the nuts/bolts and rounded them. Red Loctite guarentees they stay put.
![](http://www.icer.net/Exting_bottom_out.jpg)
Tools required for the job. The small screwdriver prys up the plastic lock-tab on the seat runner trim above the mounting bolts. They just slide right off, exposing the two Torx bolts. An E-12 Torx socket, 6" extension and 3/8" drive is it!
![](http://www.icer.net/Mount_tools.jpg)
Here she is in place....
![](http://www.icer.net/Exting_In.jpg)
I can easily take a bit off the bottom of the plastic trim pieces and put them back on but I need to take this out to get a child in back so haven't bothered.. yet.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I did opt for the $140, Option 509, Fire Extinguisher.
It is nicely done and out of the way...don't even know that is there.
Highly recommend this option (a best value) for those ordering.
I wonder what the parts counter gets for it after the fact?
A 987 owner bought the factory one. I assume it is the same as the 997. Problem is it would only mount on the drivers side as the bracket would not fit on the passenger side. But there might be a RHD version.
Originally Posted by 930man
i like Garys look... go ahead and make me one gary! yeah ill send the money asap! lol
thanks for the idea
thanks for the idea
The diamond plate piece cost me about $20 at metal Supermarkets... you can get the same extinguisher in red for around $100 I think.
