997 parts, members click here!
Former Vendor
Hey guys, offered a lot of deals to the 996 guys, figured i would extend hte invitation to you as well
H&R Sport Springs Porsche 997 Carrera 05+
SPORT The most popular spring in H&R's line-up, Sport Springs will lower your vehicle 1.2 inches in the front and 1.2 in the rear for a lower center of gravity, improved handling and a more aggressive appearance. Sport springs feature a spring rate that is firmer than that of the OE Sport spring, but is still comfortable enough for daily use. Sport springs are an excellent choice for street and occasional track use.
you can not safely put these springs on 997's with the PASM option
Spring kit designed for the 2005+ 997 Carrera coupe ONLY.
$323.99
EVOMS Porsche 997 Carrera Short Shifter Kit
Porsche 997 Short Shifter System:
Shortens Shift Throw by approximately 20%
100% BOLT ON – Zero Modifications
EZ Do-IT-Yourself Installation Instructions Included - Installs in approx 1 hour
CNC Machined to Exacting Tolerances
incorporates Spherical Heim Joint for More Precise Shifts
Significantly Reduces Shifter Free Play
No Slack bearings now included in kit
StopTech Porsche 997 Carrera 2S 05+ 4 Wheel Big Brake Kit
56k killer pic click HERE
StopTech four wheel Big Brake Upgrade for the 2005 Porsche 911 Carrera 2S (Type 997). The kit includes ST-40 4-piston front calipers painted red, black, or silver, ST-40 4-piston rear calipers painted red, black, or silver, 7075-T6 billet aluminum caliper mounting brackets, 355x32mm slotted, floating, front AeroRotors, 332x32mm slotted, floating, front AeroRotors, 7075-T6 billet aluminum AeroHats with directional standoffs, StopTech SS (DOT compliant) front and rear brake lines, Axxis Ultimate front brake pads, and Axxis Ultimate rear brake pads. Requires 18 inch or larger wheels, however not all 18 inch wheels will fit. Please check the wheel fitment chart for your car. Options: Drilled rotors - $100 per pair; Yellow or blue paint - $200 per pair of calipers and 30 day lead time.
$4270.99
We've got TechArt!
parts pictured above..
headlamp trimfront lip spoiler
side skirts
rear diffusor
rear wing
20 inch Formula wheels and GTS wheels
The 997's program incorporates TechArt's commitment to form and function and offers a front lip spoiler, head lamp trim, side skirts, rear diffusor and a fantastic adjustable rear wing. Most noteworthy are TechArt's Formula wheels in a new 20" fitment; 19" and 18" are also available. Expect complete 997 interior enhancements, sport exhaust, sport suspension and high performance engine tuning packages from TechArt later in 2005.
Call for TechArt prices
1-866-4-VIVID
updating this post so please check back often
mod please sticky this up top
$323.99
$4270.99
We've got TechArt!
side skirts
rear diffusor
rear wing
1-866-4-VIVID
If i'm mistaken (wouldn't be the 1st time) let me know.
Former Vendor
Originally Posted by BD997
your tellin me...they should have that in BOLD...most of us have PASM!!!!
Former Vendor
Originally Posted by MJones
Do you know what the spring rates are?
however, they assured me that these springs are designed to work with a factory package, they will not blow out factory struts/shocks.
Dan -
The EVOMS short shifter kit looks completely different than the OEM or the B&M kits i've seen so far here. As I have never installed either, can you explain the differences? Also, that item has no price.
The only reference to the shifter I could find was: http://www.renntech.org/forums/index.php?showtopic=2472
Thanks!
Thanks!
Originally Posted by Gary R.
Dan -
