Wheel choice for my 997
Not sure about the wheels.
I really dislike the 'S' wheels.
I was seriously considering the 19" Carrera classic wheels. However when you compare these with the standard 18" wheels on the car configerator there is really so little difference I'm not sure I can justify the cost.
I kept switching the image between 18" and 19" and back again. - Yes I can see the difference back to back but I bet only a Porsche nut could !!
I'm tempted to stay with the standard 18"'s
Also some car mags have reported better handling on the 18" wheels - ........DISCUSS !!!!
Adrian
Adrian
I can't imagine out how the 18" wheels would handle better than the 19" wheels. I would suspect that they would provide a somewhat softer ride, however. I ordered the Carrera S ("lobster fork") wheels on my 997 January build order, after obsessing on the 19" choices for a while. IMHO the Carrera S wheels more readily identify the vehicle as the new 911 over the Carrera Classic wheels.
Moderator
My order sheet has the Classic wheels for the nominal upcharge. I just don't like the stock S wheels either...
As to 18s, better ride street and track - still don't know why a few companies are changing from 18 to 19. I can only assume it's the "Bling" factor. As to tires - not many available in 19 and no R-compound I know of except the unique PSCs for the M3 CSL. Just take a look over at Tire Rack...
I hated the s wheel until I saw it in person! It is much better than the classic in 19'. Get the 19's you will enjoy them much more and they look better too!
Go with the S wheels!!!
I washed mine for the first time today. The S wheels have one nice feature. Nice large holes to clean the rims. You can even get to the interior easily. I'll have to agree, they aren't beautiful but the 19" rims and tire profile look fantastic.
Originally Posted by Richard in Colorado
I can't imagine out how the 18" wheels would handle better than the 19" wheels. I would suspect that they would provide a somewhat softer ride, however. .
18" wheels should be lighter than the 19's.
WHile weight is one of the main factors, the section width along with the tire construction are the other two factors. In other words if you have a lighter 18" wheel with the same section width tire and the same construction ( sidewall stifness and compound) the 18" combo will be faster than the 19".
F1 wheels for example I believe they are 13" or somewhere there...
I have just taken delivery of a 997 Carrera with 19" Carrera Classics. They are definitely the best looking wheels available for the 997. In the flesh they look noticably different to the standard Carrera wheel.
Originally Posted by MJones
Option 403 (19" Carrera S Wheel) is currently unavailable for 997 Carrera
The following is a quote from the November issue of Sports Car International regarding the 19 inch wheels. "The other issue that Porsche could not get away from is the fact that so many owners want to fit 19-inch wheels, either from Porsche's own accessory range or from aftermarket manufacturers. On the 996 this causes geometry problems... Because of this, the 997 was designed for 19-inch wheels from day one, a decision the engineers admit was a major cost factor in their suspension budget because it meant altering pickup points and making new castings like the wheel uprights and suspension arms."
Therefore, the 997 suspension geomertry and components were desinged to take advantage of 19-inch wheelsand I assume have the best handling with this setup.
I thought this might shed some light on why Porsche went with 19-inchers. IMHO I have the standard 19-inch wheels on my 997S and I agree with Santangelo, they have grown on me and now I really like them.
Originally Posted by dhud
...the fact that so many owners want to fit 19-inch wheels...
