Wheel Carrier ball joint insert ? Is this part available ?
One of the "S" knuckles I bought of ebay is missing some kind of pressed in serrated insert for the LBJ (the tie rod has a similar insert but its not missing). I can see no practical way to remove one from my old knuckles.
I seriously doubt this part is available individually, its not called out in parts diagrams.
Can anyone say different or ever seen someone remove one ? Nothing's impossible but there's not lip to punch it out, you'd have to grab it from underneath. I suppose I could try to cut open the old knuckle until it fell out but that doesn't sound like a good idea.
Back when I had a bad bushing, absolutely didn't exist; exchanged emails with a maker in the UK... etc etc.... I purchased new carriers. There was a recent post where someone found them: https://rennlist.com/forums/997-foru...r-bushing.html
Thanks I appreciate the input. I read those threads and they are concerned with the rear shock bushing. This is actually some kind of serrated insert in the LBJ. After doing my own research I think I'm out of luck and will need to source a new knuckle. Even if I could get one out of my old knuckles, its such a critical part I wouldn't feel comfortable installing a used bushing that was removed from an old knuckle and pressing it into another used knuckle. This is a mission critical part obviously.
It’s the steel insert with a tapered centre for the balljoint (either on the outer end of coffin arm, or the outer end of the steering rack tie rod balljoint) and the outside is knurled to fit into and grip the aluminium suspension upright/hub carrier.
Unfortunately it’s not available separately (it’s supposed to be retained in the aluminium of the upright by the external knurling, but when the balljoints get stuck in the steel retainer, they get hammered out and the insert comes loose.
You can see the two knurled/serrated inserts in these images :
I’d buy a cheap used upright and remove the steel insert (it only comes out one way, as it has a shoulder) and Loctite it into your existing upright.
You can hammer the insert out of the old knuckle and re-use it. I did it a few weeks ago by accident. I was installing new adjustable toe arms and when removing the old ball joint the entire insert came off with it. I've talked to multiple shops and they've all said it's okay to re-use, the serrated edges make it fit back in properly without worry.
The only thing to figure out is if you can put some type of pin from the top down that you can hammer through the center. I wouldn't use something like a flat head to get it out.
Well that's weird I could have sworn I posted an update to this a couple of days ago. I didn't see any way of getting something in there to hammer the insert out its concentrically flush with the aluminum and there really wasn't even a gap to try and get in at all. So I did it the hard way and used a series of grinding tools to cut it out of my old knuckle. I was careful not to nick it in any way, and was able to press it into the new knuckle with a bearing press. I put the insert in the freezer first and it was still a pretty tight fit, so I think it should be good. Tightening down the ball joint clamps this piece in there anyway, so only real concern would be if it was compromised and cracked or it could potentially come out with the ball joint next time they are separated, but I'm pretty confident its in there solid.
