997.2 rear shock lower bushing
Hi,
Does anyone replace the lower shock mount bushing, the one in the hub, when changing the rear shocks. I can’t see a part number and wonder if it can be replaced or if it is part of the hub itself.
2009 C2S 196K miles
You can't replace it... you must replace the entire wheel carrier (AKA knuckle). I did this in 2019 at 140K miles. This is a really big job. Read about it here: https://rennlist.com/forums/997-foru...ed-advice.html
I contacted various bushing makers, the one in the UK has alternative bushings for every part of our car except that one insert. They told me it is a nightmare, they stopped making them, and I had to replace the carrier. So I just replaced the whole thing and did both sides. I also chose to replace the wheel bearings given the mileage on my car and this huge effort to do this work. I could do all the work myself except I had to take the carriers to a speed shop for them to press out/in something... I can't remember what it was... see my wrightup. Looking back on it, I should have just purchased a Harbor Freight press for $170 as the shop used just this model for this work.
BTW, why are you doing this and how did you find the problem? I used chassis ears to find mine.
Peace
Bruce in Philly (now Atlanta)
Peace
The car is a 2010 with 92k miles on it and I was thinking about completeness as other parts are getting replaced, I don’t think it is in need of replacement because I’m sure that a light creak is from the top mount, hence new shocks, mount's, etc.
Given your experience I think I’ll pass on replacing the hub, thanks for the input.
John
John
Elephant racing makes a replacement monoball and removal tool for the lower mount bushing. When it’s time to replace mine, I plan on going this route. It costs under $500 for a pair and the tool.
Monoballs 997 rear lower struts
Let me know if you have questions.
Peace
