High mileage 997.1 3.8 150k miles - short block replaced
Looking to buy a high mileage 997 with 150k. According to car fax, at 98k miles this happened. Is this related to the bore scoring ?
Vacuum leaks repaired
Spark plugs repaired or replaced
Internal short block components repaired or replaced
Also at 143k miles this happened.
Exhaust repaired
Exhaust manifold gasket replaced
Oxygen sensor replaced
Fluids checked
Front brake pads replaced
Oil filler tube replaced
Serpentine belt replaced
Coolant reservoir replaced
Antifreeze/coolant checked
Oil and filter changed
Should I be concern at all? Few accidents as well but no air bag deployed. Full service history at dealer. 2 owners only.
Exhaust repaired
Fluids checked
With the number of 997 for sale there is no such thing as a cheap Porsche you will pay sooner or later but much $$$ will leave your wallet
look for a well maintained car
The following 2 users liked this post by EVOMMM:
groovzilla (03-17-2024),
waterpanda (03-18-2024)
2009 C2S 196K miles
These cars are super expensive if dealing with engine-related issues (beyond a pump or sensor). Unless you have deep pockets, there is no way I would buy a car like this. If you are really really interested, I would find out who did the work and contact them for further inquiry. I have spoken to many Porsche owners who had engine problems and had some local shop do the major repairs, most of which quickly sold their cars off. They did not do what was required... including installing iron sleeves and only in the worst-case bore. Said another way, major engine work on these cars is super expensive to do it correctly and my first suspicion when discussing a car that did have major work, is to assume it was done on the cheap.
Good luck, let us know what you do.
Peace
Bruce in Philly (now Atlanta)
Peace
8x57IRS (03-18-2024)
Price? Records of service? Neither scares me as 50k plus miles ago was the engine service and the service 7k miles ago seems mainly maintenance related. But as others have said it isn’t the car for me. But for you…..
I think it comes down to your wants, financial stability and ability to deal with headaches. If you are reaching to buy this I wouldn’t as it will still have 100k car upkeep. If you are buying for a daily driver I would find a nicer example as this may give you some headaches. If this is a third or track car and the price is in the mid to low 20s I’d say proceed cautiously.
What do you plan on using it for?
2009 C2S 196K miles
Peace
Peace
for my car, all maintenance was done at dealership.
All work was done at the dealership so I might call them tomorrow to find out more information. It runs and drives fine. Suspension has no leaks and takes sharp turns with ease. No leaks anywhere.
3rd car for weekend sprinted driving. Price is below 20. It needs other work like convertible don’t work right weak opening, spoiler button don’t work, pasm don’t work. Check engine light for O2 sensor, minor leather crack. Exterior is decent. Im planning to run a full dme report on it from a foxwell tool to check for misfire or anything I can.
for sure no investment for this car. I just hope I don’t have to drop 10k soon on it and get to enjoy it for at least 20k
highly doubtful!!!
the previous owner couldn’t or wouldn’t address simple fix issues
only convinced me that you’re going to spend lots of money on this car
Under $20K is the right price, but it is often the case (on this board anyway) that the new owner immediately finds himself spending $5K in parts (plus whatever labor) in order to keep this car running. At 150,000 miles, there are lots to be done.
yea im going to hook up a foxwell to it and test the spoiler and psm function without the buttons to see.
