997 Metal Shavings in oil filter and on magnetic plug-Help
Not good News....I just got a call from my Porsche mechanic....a fair amount of shavings on my magnetic Plug and in the oil filter. I am 4,000 miles on a rebuilt motor which i completed. Car has been running okay but has been misfiring, and getting P0021 error Codes among a number other error codes ( replaced the adjustors...same problem of the P0021). I believe the timing could be off by 180 degrees (a potential huge screw up on my part) which is why i wanted the mechanic to look at it as I have ruled out almost all the other regular culprit's (fuel injectors, ignition coils, MAF, CO2 sensors).
I have done 3 oil changes in the 4,000 miles break-in and did not see any shavings...but now about 1200 miles after the last oil change, i have shavings. What are the potential causes? everything inside the engine is brand new. I am trying to understand what i should be focusing on. I am going to have my car shipping from my mechanic to my house where it looks like i will need to drop the engine and starting searching for the issue. Any comments or suggestions would be appreciated
Obviously not good news.
What is the oil lubricating that is ferrous is where my mind would go...but an engine teardown is in order.
Rings, timing chains, timing chain gears, oil pump gears, camshaft, ...
Do you know generally where the ferrous shavings are likely to come from?
It is my hope for you that all of the shedding material was pumped to the oil filter and that the crank, cylinders and pistons are OK.
anything with iron (-> attracted to the magnet) in it...the list I shared and am I certain I missed something. If the failure took any non-ferrous material with it, aluminum, rod/crank bearings, etc with it, that will not show up at the magnetic drain plug but everything will show up in the filter.
That would have been my thought but I was told it was possible...and i was running out of potential causes for my misfires and other error codes. Mechanic just told me my timing looked fine based on his Porsche Code reader. If timing was off I would consistent misfires whereas mine are random.
Did you do the rebuild yourself?
Yes using Jake's step by step rebuild course. Block was bored out with new cylinders, pistons/rings by Hartech. only internals not replaced where the chain tensioners....which might be the potential problem. Crank, Cams check measured and polished, all other internals replaced. Waiting for analysis of the ferrous shavings found in the oil filter
Also, you might as well drop the oil pan, wash off the collected material in its bottom and do the aforementioned steps on it too.
This may give you some hints as to what happened.
stupidly ...comments on Various forums putting them less critical for replacement if they tested fine. Car only had 55,000 miles....now i would just say potentially painful mistake if they are the route cause. My penance is to drop the engine and hope that was the only problem
It might be worth liberating the shavings from the filter into a plastic container of solvent. Decant the solvent a few times until it is mostly clear. Then stir a magnetic pickup in it. Place the collected material on a some thick white paper or piece of poster board. Repeat a few times. Some non-ferrous material might find its way with the ferrous material but it won't be much. The material left behind in the container is non-ferrous so place it on its own white piece poster board. Now start having a detailed look at the two samples.
