wiring guru needed
wiring guru needed
Hi Guys
Am in need of some help regarding wiring to and from the starter relay because i cant get the starter to crank,
Am in the process of doing a engine conversion and running a standalone ecu.
I've searched for various diagrams but some of them are poor quality once you zoom in.
I no the thick black wire is a live and the thick red/blue goes to the starter but am unsure where the smaller gauge wires goes to. Any help/detailed diagrams would be great
thanks
andy
thanks
andy
Does your dash energize normally?
that's awesome, thanks' a lot. its a 2006 c4s so i presume i would use the earlier model?
just out of curiosity, what program/website are you using for the wiring diagrams? it could be useful for me later in the build.
There is a cluster of relays just above the fuse panel and one has to do with the starting circuit.
That's Relay Support 1
...and there's also relay support 2 back by the DME under the shelf
username vtecknowledge and engine conversion with a stand alone. Let me guess, K24 swap?
https://rennlist.com/forums/997-gt2-...copy-here.html
I have access to Mitchell1 Prodemand at the shop I work at.
https://www.prodemand.com
Based on the picture that you showed I think you are the later production.
