Warning for fan blower?
I have an error on my 2008 C4S cabriolet that pops up from time to time. I need to take a pic but haven’t yet. It’s something like the “fan blower.”
I don’t have the AC on and it comes and goes. The car does have a supercharger, but since that’s aftermarket, I don’t think it has anything to do with it.
Has anyone else experienced this?
I had this happen yesterday in my 08 C2S.. "Engine Compartment Blower Fan Failure" I had my A/C on max and it was 112° here in the desert. The error message went away so I'm hoping it had something to do with the A/C on max and the temperature. All engine temperatures were normal, but it did scare the crap out of me. I did another quick run in the afternoon without issue. I read that there is a fuse for the fan that should be upgraded to a 15amp. I'll check that if the problem comes back....
MarkTro (08-19-2023)
Do you hear the fan inside the engine compartment working when the car gets hot? It's probably related to that. You can't test it with the decklid up as there's a switch 8n the latch that won't let it run if open. You could however put 12v directly to the fan contacts and see if it runs. If not, you need a new fan.
Here are a couple of links with info about changing out the 3amp fuse with a 15amp fuse.
Blower Fan Failure
Blower Fan Failure
