Blower Fan Failure
Blower Fan Failure
A friend's TT has encountered message that blower fan has failed.
The fan no longer activates, we unplugged it and have powered the fan from an outside power source and it works fine.
The electrical cables don't appear to be crimped or broken. Fuse in footwell is fine.
Anybody have any input on this? Thanks.
What about the engine compartment temperature sensor?
Also, there is a fuse but there also might be a relay associated with the fan. You'll have to consult the fuse/relay booklet in the lid of the fuse box to know for sure.
That takes the fun out of problem solving. If that is the solution to all small service issues then this forum would need not exist.
The following 2 users liked this post by Goldstar:
Backday (06-09-2021),
Robocop305 (09-03-2021)
Since the fan works there's the engine compartment temp sensor or the DME. (Or maybe the fan is only bad when it is hot...)
If your friend doesn't want to sully his shade tree mechanic go it alone rep by asking a pro for assistance then advise him to buy a new engine compartment temp sensor.
If that doesn't work then maybe consider a new engine compartment fan. If that proves not to be the problem fix have him price a new DME. When he hears the price of the new DME he'll wish he'd consulted a pro about this.
In fact I expect he'll wish he had when he hears the price of the new engine compartment fan.
Totally disagree. Throwing money at a mystery problem is no solution. It cost nothing to get the codes read. They will tell you what to replace the first time..
Even if someone here had a similar issue that doesn't mean that the solution would be the same..
Driving my 08 TT for the first time in summer heat since buying it last fall. I know the engine compartment fan ran last fall. but I got a warning on the instrument panel last week after driving it in 85 degree weather. I turned the engine off and the message appeared and the red warning light in the temperature gauge started blinking. Researching the internet showed that the failure could be a blown fuse. The fuse in located in the relay carrier behind the back seat. Found a good, fully illustrated write up on how to access the fuse for a coupe but I have a cabriole. I haven't been able to find similar guidance as good as the coupe instructions.
I did manage to figure out how to put the convertible top into the service position to access the area where the carrier is located but I need to remove the carpet over the engine to get at it. I see there are two round button clips in the middle that should be straight forward to remove but there are also two hard plastic "saddles" on each end which apparently are used for operating the top. I can put my finger under the saddle to feel the end of a self tapping screw which is holding it in place but there is a plastic cap over the screw head at the base of the saddle. See pictures.
Before I go crazy with a screwdriver and scar up or disfigure the saddle caps, I thought I ask to see if anyone has removed these and can share the technique they used.
My Porsche club chapter has a 3 hour drive coming up this Saturday and the temperatures will be close to 90 for the entire trip. I'm sure we will leave the top up and run the A/C which will cause the engine temps to go up. If I can't get at the fuse before then, is it safe to drive it under those conditions if the fan does not work?
RennKit-Dave (06-10-2021)
Basic Sponsor
You may find further info here: https://rennkit.com/rennkit-home/996...als-brochures/
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Many thanks for the help in informing me that the "saddles" do not have to be removed to remove the carpet. I got the carpet moved away and found that one of the 3 amp fuses was blown. Replaced it and will find out tomorrow when I go for a club drive if that solves my fan problem.
FYI - my car was built in Aug of 07 and had a 10 amp fuse where the 7.5 amp fuse would have been. I have read that Porsche put out a service bulletin to replace the 7.5 with a 10 and my car must have been come from the factory with a 10 amp fuse.
Well I went on my club drive today for a total of 3 hours of driving in 90 deg heat. Coolant temp was a steady 175 and oil temp was just a little below 200 all day long. Unfortunately at our first stop after an hour and a half when I restarted the car I got the engine compartment warning again. On our second stop the same thing happened.
I didn't look after I got home but I assume I blew the 3 amp fuse again. Anybody got any ideas where to look next to find out why the fuse keeps blowing? I thought I'd put 12v on the fan leads to ensure that it works but after that I don't have a clue.
Agree, confirm the operation of the fan as a next step.
Honestly, I hate how these fans are set up. To rule things out, any mechanical blockages (e.g.leaves, twigs, etc.)?
After a quick search, it seems people are replacing the 7.5/10 amp fuse with a 15 amp... and it solving the issue.
After some internet searching I found a couple of posts about recall "W737" that apparently reprograms the DME to eliminate the low speed fan cycle because it would always run. Anybody know anything about this?
If you haven't blown the fuse, check the relay.
Ed
Ed
