Audio upgrades
#46
both of these amp install look clean. How did you mount the amp racks? I’m working on a similar project and keep getting concerned about drilling so close to the fuel tank. Thanks
MarkTro (03-20-2024)
#47
The OE Bose amp was located in the frunk on metal risers or tabs (factory). I removed the Bose amp and made an amp board to mount to that same location of the Bose amp, so no drilling required and no worries on puncturing anything. If that makes sense.
#48
I'll have to take closer look at the original Bose mounts. I originally planned to make a rack that would replace the cover that houses the tire pump and toolset. Got as far as getting the board secured to the nubs on the floor but can't decide how to attach the upper side. I'm using two 4 channel amps, separate left and right, which is completely excessive and oversized, but thought the challenge would be fun. Now wishing I just bought one of those small audison amps... Thanks for your reply
#49
I went through several revisions on amps (from old school 1990's) to the current MTX class D. Its loud and sounds great as it sits now. 4 Channel for the highs (8-4-1 speakers) and 2 Channel bridged to 2ohm single 10. Mounted the Kenwood GPS antenna under the center speaker grill.
#50
I'm sure it sounds great. I'm trying to overcome the limits of a convertible and wanted to try a DSP this time around. The minidsp cdsp fits nicely where the cd changed used to be. Still haven't quite sorted out the subwoofer placement though, was thinking a single 10 in a sealed enclosure in the rear driver footwell area. MarkTro, did you also use the factory amp standoff to mount your amp rack?
MarkTro (03-22-2024)
#51
Happy to help if you have questions.
#52
Here is my setup.
Mosconi amps (240.2 bridged for sub) (240.2 for 2 bass) (120.4 for mids and tweets) Mounted on a panel that sits at the bottom of the frunk. Covered with stock frunk panel so you don't see it when covered.
Helix DSP3 fed from stock PCM 3.0 that has been set to Sound Package plus. Custom wiring harness made to send line level signal for FR, FL, RR and RL from PCM to DSP.
Scanspeak Mids and tweeters
Dynaudio bass
Infinity sub in custom box in space of removed rear seats
Dynaudio bass
The following 3 users liked this post by PapaC4S:
#53
Here is my setup.
Dynaudio bass
Dynaudio bass
Do you have any more pics of the custom sub enclosure? Did you make it or have it made? What is it made out of? I'm about to start my fiberglass enclosures in the same place and would love to see options of what you did.
Great job!
#54
Thanks. Here are some more pictures. I made it out of Baltic birch. 10" sub facing down behind the driver. Hinged cover over storage compartment on passenger side. It is held in place with brackets that bolt into the seatbelt attachment points.
The following 2 users liked this post by PapaC4S:
MarkTro (03-26-2024),
Rig.Stunts (03-26-2024)
#55
My plan was two 10" subs, but I do like the storage idea. How is the bass? I was going to up fire them with the seats down, so they would be firing into the seats that are folded down. I thought that would essentially do the same thing as dowqfiring, and would allow me to have a bit more in the way of cubic area inside the enclosure as I would not need the stand off.
However, I would LOVE to hear what type of experience you have with yours. How much power are you running into the sub as well?
Thanks, this is so cool to talk about this stuff again!
#56
The Mosconi amp puts out 680 watts to the sub. It is a lot of bass. I have the entire interior covered in sound damping butyl tiles as well as mass loaded vinyl so it is pretty quiet to start. The sub only needed a 0.6 cubic feet box so pretty small enclosure. I can't imagine needing 2 subs. I have 8 inch Dynaudio drivers in the doors with 240 watts each so drive pretty hard down to 50-60HZ, the bass is fairly distributed.
#57
Thanks again.
#58
Here is my setup.
Dynaudio bass
Dynaudio bass
MarkTro (03-27-2024)
