PDK - Defective Temperature Sensor Crimp - Repair Procedure
Hi folks,
Info about this has been posted in other threads (e.g. PV997's PDK repair thread), but thought it might be useful to have a single thread specifically focused on this particular failure, might make it easier to 'pop' if someone is searching/finding...
First thanks to @Janton9736 for posting the repair-procedure at the following. A copy is attached for quick reference...
https://rennlist.com/forums/997-foru...l#post16183150
Per the attached, if the temperature sensor crimp starts to fail, the user can experience the following errors:
Porsche published a Service Bulletin (attached) with the following IDs:
The repair specifies the following parts:
More details in the attached.
Note that it references "3730 - Flow charts for PDK fault codes", link here - https://static.nhtsa.gov/odi/tsbs/20...43332-8620.pdf
And of course PV997's thread has additional details (e.g. the utter ridiculous guidance to replace the transmission if there's a few loose strands) - https://rennlist.com/forums/997-foru...nsmission.html
Karl.
PS: If anyone spots an error or omission, please shout out so I can update this post.
PPS: Beck's European has seen a case here a bad PDK Speed Sensor resulted in a P17F1 error, more details here: https://rennlist.com/forums/997-foru...l#post18619629
- Warning message "Gearbox emergency operation"
- P0711 with P17F0/P17F1/P17F2
- P172D by itself or with P17F1/P17F2/P17F2
- NHTSA ID: 10108671
- Porsche TSB ID: 122-W9N9W-06
- 997.612.930.01 - Transmission fluid temperature sensor repair kit
- 9G1.321.025.00 - ATF pan, complete (with aluminum screws and drain plug)
- 000.043.207.78 - AD-1377 Crimp Tool - (psc85c found a less expensive version here: https://www.digikey.com/en/products/...08-000/3318003)
Karl.
dougdtx (02-06-2023)
