Upgrade priorities
#31
#34
Very interested in this once it releases. Will it come with a MOST adapter for Bose units or can we add it on? Also will it support wireless CarPlay?
#35
most-hur adapter will be available for approx $100 (as i believe all android pcm's have optioned). I always recommend getting the canBus adapter as well since for some cars it will successfully pass the reverse trigger (vs having to physically get the signal from tapping into a reverse wire) + steering wheel angle sensor information - but in all cases the canBus will passes additional canBus signals such as mulfi-Function steering wheel info and so on.
i have finalized the design last week to maximize/clean-up the look + functionality of the PCM (based on certain technical limitations) - and a 997.1 grey sample unit based on the popular nissan kr2 color code is being made.
I will test that when It arrives + I will certainly update when I get an update myself.
Be sure to join the FB retrofit + modification forum as I have uploaded a 30 min video demo of the unit. Thanks !!!
trban8r (09-23-2022)
#36
My personal order of mods.
Assuming you have done a Bore Scope inspection and confident your engine is healthy, I do the following hit list:
-Lowering with H&R springs
-Short Shift Kit
-Gundo PSE Hack or Fister Mufflers for the great deep throaty exhaust sound.
-Bluetooth added to PCM radio
-Short Shift Kit
