Advice on airbag light
Old Aug 8, 2022 | 06:00 PM
06flat6's Avatar
06flat6
Default Advice on airbag light
The battery in my 2006 Carrera S died this week. I recharged it and now I have an airbag warning light.
I purchased it used (it's high milage) and someone else's pre-inspection that I got a hold of before buying also showed the light on. When I received it a year ago it was not (and has not gone on since).
Any advice? Is this common? Any simple diagnostics or solutions, or should I just take it to 'my guy'?
Old Aug 8, 2022 | 08:03 PM
ATX_Native's Avatar
ATX_Native
Try searching…
Airbag light on after battery drain
New battery, airbag light on
IMO, just bite the bullet and get a Durametric.
Old Aug 9, 2022 | 08:25 AM
Petza914's Avatar
Petza914
An airbag light won't clear.itself. You'll need a code reader. It can also tell you which airbag or seatbelt sensor is causing the error.
Old Aug 9, 2022 | 10:33 AM
noofus's Avatar
noofus
I just bought an iCarSoft POR II from Amazon and was able to clear my airbag light. It's a lot cheaper than a Durametric. I would give that a shot. And really, it's not a bad thing to have a diagnostic tool around with cars this old
Old Aug 11, 2022 | 11:19 PM
FlatsixS's Avatar
FlatsixS
i did the same. Also you can use for resetting oil change date.
FlatsixS
