Low Oil Pressure after bouncing a curb
Was leaving my driveway and unfortunately the rear end bounced off the curb, just shortly after when slowing down / idle clutch in I receive a notification of "low oil pressure warning" for less than a second and it disappears. This has now been happening when driving at temp. It definitely seems like a loose sensor but wanted to get some feedback. Car cant get into a shop for a week or so as they're booked out.
06 c4s
06 c4s
Any fluids on the ground? Would be worried if you have converted oil filters to metal you might of crushed it.
06 c4s
06 c4s
Jack the car up and examine for any leaks or obvious damage.
Always a chance on these cars to damage the engine when hitting pot hole, curbs, etc. Usually damages the sump plate, but depending on how you hit the curb, there is a slight chance you damaged the oil pump housing or called the front console. (see arrow in image)
What does the oil pressure gauge read with the key on but engine not running? Is it showing zero or something else.
What's your oil level via the gauge?
If you hit the oil pan hard enough you may have pushed and broken the pickup tube that sits right on the bottom of the pan. Is your oil level still at the proper level? If it is I would bet this could be the issue.
No. You wouldnt flex the sump cover enough to push up the pick up, which has a bit of play anyway, without the cover itself breaking. A hard hit may have temporarily jiggled the innards of the pressure gauge but the engine is likely just fine
Follow up, the pop up has become less frequent, ive yet to get a chance to pull it apart and take a look at the sensor. I've never seen the gauge go below .5 bar and it idles around that
