I guess it's my time.
Here is my plan: I am driving it for another few years or until it does not pass smog anymore. Then I will disassemble the engine to the block. Send it out to LNE for repair and the put it all back for another 100,000 miles. Do you think it will last 2 years?
Cyl 1, good except for oil pooling
Good.
Oil pooling past the rings
Oh well, here is some scoring
Cyl 5 is good
Cyl 6 is scored about the same as 4.
It's super frustrating, but I've already long decided that I will keep this car. It is special to me, and if I have to tear her apart, then she will be better for it. The fund for a rebuild is in place and I'm treating her as kindly as possible to avoid or delay what I believe to be inevitable. It is strange, no doubt, that I don't want to know for sure. I really don't have much to say about that...
I bought mine without a PPI, because I'm a genius and so far, it runs great! I have done a ton of work to this car, mostly cosmetic - all new leather console and side panels, new head unit with backup cam, changed out some scratched up parts, painted the stereo stack bezels black, all new paint on the hood, fenders and bumper with PPF, turbo rims (lobsters are in the attic), new engine mounts, water pump, LTT, changed tranny fluid to PTX, did the tranny mount insert from function first, numeric short shifter with BFI heavy shift ****, frunk lid liner and more. Also switched to Drive DT40 oil and the spin on oil adapter for a K&N filter as I was told that would help stave off additional bore scoring... we will see after the next oil analysis if that did anything. My numbers were triple the norm ...
Good.
Cyl 5 is good
If I were you, I would just look around for a while and buy a nice warm climate (Calif/Tx/AZ) used 997 engine that has been Bore Scope Inspected - I'm sure you can source one for $15-$16K.
Drive your current engine into the ground. Then do the swap with your nice clean Bore Scoped $15K engine that's sitting in the garage ready to go..
Think about it:
In 2-3 years when you will need to replace your engine, if you go the rebuild route, the parts will have gone up dramatically (like they are doing now) as well as huge labor costs.
I'd bet a rebuild will be close to $35K in 2-3 years.
I would go the used engine route. Just my 2 cents.
I've been thinking about buying a used 997 engine and just hanging onto it in garage. Why the hell not? They could become somewhat valuable as we move forward. Also if I find a 997 basket case it would be nice to have the spare.
*Wish I had bought the 1956 356 Carrera 1500 GS engine in crate I was offered 37 years ago.
Google around. Jake Raby helped someone in the same issue and recommended some special, heavier oil to make it last longer. Or drop him an email and ask his advise. He is so backed up, you may be able to get yourself into the waiting list for two years out. She is gonna blow... it is counting down. I would rather get a repair done before there is collateral damage and then not be repairable.
Peace
Bruce in Philly (now Atlanta)
I am just thinking through the logistics. In one more year, my daughter will graduate college and I will buy her a new car. Then I will use her current car (Audi A3) as a daily driver for my wife while I work on her 997 for 6 months. Send the block out, do the valve job, repaint the bumpers, repaint the lobster wheels, assemble the engine with new pistons and rings, paint correction when done.
Peace
- before you have piston “knocking” consider shortening the oil change interval (2k to 2.5k miles) and using an oil that does a good job of cleaning out the small metal particles - Jake recommended to me Liqui Moly 2040 Synthoil Premium SAE 5W-40 Motor Oil.
- I saw an older video where Jake recommends a special Cummins diesel oil if you need to drive the car after you get the piston “knocking” sound. He doesn’t recommend driving it under these conditions but does suggest an oil that can help if you need to drive it.
I am on the 2k mile oil change interval w/ the liqui Moly 2040/2041 (one is the 5 liter package) and I do an UOA after every change and have started cutting my spin on filters open to inspect them. I also have the LN LTT, magnetic oil drain plug and spin on adapter.
driving the beauty until one day my number comes up and I start getting piston knock. That’s when the driving stops and the engine rebuild begins. I have the money set aside to do it when it happens. You can spend it up front w/ a .2 or you can roll the dice and plan for spending it to get a 4.0. But I gotta say, not worth it if you don’t absolutely love these cars.
to do it. After that your family will be so pleased to have that particular 997 with that original (rebuilt) engine in the family!
And I hope your wife and daughter appreciate the automotive wonders you have been so thoughtful about providing for them!
My 2c.
Mine started showing symptoms around 27,000 miles. I drove it to 47,000 miles before getting the engine rebuilt (LNE all the way, including IMS Solution, new clutch and AOS, 4.0 liter bore plus new pistons, pinned IMS shaft sprocket, etc.).
I had tracked the oil condition via routine changes and UOA every 3,000 to 4,000 miles. Except for carrying extra oil around with me all the time and filthy LH tailpipes, you would not have known there was a problem by the way the car drove. I did not change to a heavier oil, but I would have given today's knowledge. However, adding oil with nearly every tank of gas was truly depressing.
My purpose in driving and delaying the repair was primarily financial -- it gave me a couple of years (at 10,000 per year) to save up. I am pretty sure I could have driven it a little longer, but the oil consumption was going up with increasing speed (almost describing a parabola) and was about 300-400 miles/liter when I threw in the towel and had it rebuilt. The UOAs were showing more metal and more fuel dilution and I did not want to risk totally trashing all the good parts of the engine.
Now, 35,000 miles into my rebuilt engine, it's really nice to not worry about my car since all of the known engineering weaknesses got addressed during the rebuild. My plan has always been to amortize the cost over many, many years by driving it forever. I originally thought the rebuild would give me another 100,000 miles (like you), but the way it feels, I would not be surprised if the engine lasts much longer, and I ultimately end up spending more money on the chassis than the engine as it ages and wears.
I would advise not being afraid to drive it now, but monitor all the usual vitals (oil consumption and UOAs) and pull the rebuild trigger the second you can afford it.
With the fear and anxiety of an actual case of bore scoring completely behind me, it is a wonderful car to drive, and I look forward to driving it every single day!
