997 c2s overrev
997 c2s overrev
I am about to pull the trigger on a 2007 c2s cab. The car has 25kmiles and is in basically tip top shape mechanically. The garage that did the ppi for me (not porsche) scanned for over revs and the results were 5436 range 1, 405 range 2, 49 range 3, 7 range 4, 4 range 5, 2 range 6.
Should I be concerned at all? I don't think it's possible to actually have these small values from 4-6. Would you guys buy the car?
There are 3 ignition pulses per engine revolution so it's not impossible to have these small values so the question is whether this was insufficient time to cause any serious damage. The Range 4 - 6 ocurred for less than a fraction of a second. If the overrevs occurred more than 50 hours ago, most shops get comfortable that no significant damage occurred. You can always have a compression test or oil analysis performed for peace of mind, which is what I would do.
zygomatic (02-09-2022)
There are literally thousands of threads on this topic.
Also, you don’t have all of the info. You need to know when these happened.
However having said that, these are fine due to the low count over Range 3.
All depends when the over revs in #4 5 & 6 took place. Not always good news when there are over revs in 5 & 6. --->I had a 997 years ago with 1 over rev in range 5 and 1 in range 6 but it was when there were only 20 hours on engine and it was considered a battery blip or computer blip so wasn;t a concern.
Car I PPI'd last year had 6 over revs in range 4 but they were only 2 hours old so it was a concern.
Get the info on what the engine hours were when the 4/5 & 6 over revs occurred. That is key info.
**Also what are the Cam Deviation numbers?? Important info. Too much Cam Deviation not good.
So what's the impression of a car with 5,436 range 1 marks and some questionable 3-6 hits? Some will be fine with it. Others who want a gently driven car will walk and say....no thanks to a car with next to 5,500 range 1 marks and some higher on the record. Hard to make the case that this was a car that was driven "gently". Just my feel on this car...given a good PPI by a reputable indy or a dealer other than the one selling the car I wouldn't reject it but it also wouldn't stand out as exactly what I was looking for.
We need the hour stamps and the total hours counter to make any conclusions.
There's another angle to this which is brought up now and then. My dealership service advisor always told me they won't CPO a car with anything with DME readings 3 or higher. Never mind 4-6 no matter how minor the time spent there. Many buyers see it as a blemish on the car no matter what. It also comes down to personal tolerance. Some want a car that's been driven gently. Others are fine with a car that's been driven hard but not abused.
