Question: What did you buy for your car? Wasted Money
#46
No, there were 3 or 4 or 5 generations of crap toggles from ClimaRepair before the Revolution versions that seem to maybe be decent were introduced.
#47
Yeah, I am part of a group of tri-state area Porsche friends who get together for annual work on cars days. Most of them have Boxsters as I had a Boxster before and joined them back then. Some of us have moved to 911s but we still gather and have fun working on cars. There’s about 20+ of us and most if not all just use the Mobil 1 0W-40. Some I’ve seen maybe use Castrol or AMS oil, but I haven’t seen anyone use Motul or Driven. I don’t think they even know about it. Same goes with the MoS2 moly additive. None of these guys have had IMS or other engine issues over the years. I think if they came to this site, they’d be scared. LOL.
I’ve since switched to M1 5W-50 on my 997 cause I think it has more protection from shear than the 0W, but not sure if it makes much difference.
The manufacturer also recommends 10k mile oil change intervals. Curious if your following that recommendation as well.
Just because a manufacturer receives a boatload of money to endorse a prosuxt and put that label in your engine compartment doesn't necessarily make it the best choice. The only thing most manufacturers really care about is getting the car through the warranty period.
So no, I don't take Porsche's recommendations as gospel but as for Mobil oil vs. the much more expensive options I just haven't seen any conclusive evidence of benefits of the fancier brands.
Would be interesting to hear from the real high mileage 997 owners on this. Bruce in Philly (I guess Atlanta now) comes to mind with I think close to 180K miles on his car now. What kind of oil have the real high mileage guys used to get to where they are?
#49
Wayne and Bruce are probably the high mileage guys and I think both use Mobil 1 so maybe it's fine, but less wear.metals in UOA reports are.betternthsn more wear metals and I consistently see lower wear metals and better viscosity numbers from other oils in people's UOA reports. So maybe Mobil 1 is good enough even if something else is better.
#51
That saves them a fortune in replacement engines just by putting that into print. I'm very glad none of my Porsches shave this kind of oil usage because I'd bet they have the poor compression numbers that correlate to it. The fact that some engines have this kind of consumption and other don't says something about their manufacturing tolerances which is guess is also why some engines see bore scoring and others don't. It's also possible that a higher oil consuming engine is less likely to score because it's looser or that may be the case in a 997.2 where scoring is usually a seizure, but the opposite in a 987.1 where scoring is usually from piston rocks and skirt contact.
#52
This is why I wonder if folks here didn’t rush to a rebuild at the first sign of scoring, just how long their engines would continue to last given the tolerances of these engines. I mean, an engine starts dying from day 1. If you are going to spend $30-35K on a rebuild, why not just keep running it as long as possible and then do the rebuild? I can understand if you are getting CELs or engine clanking or what not, but if it runs fine, why not just keep driving and enjoying it?
#54
I regret spending $3500 on a new clutch and upgraded IMS bearing when I first bought the car 18k miles ago. Both are getting replaced when my engine gets built by FSI in a year.
