Best Sounding Exhaust
Great choice that I should have mentioned in my earlier response. Had it on my -09 C4S and loved it. To the OP....Tubi comes complete with side cans and center muffler delete x-pipes so no need to mix and match. https://www.suncoastparts.com/produc...SABEgKAIfD_BwE
Not the cheapest solution available for what you want but some who went with the cheaper solutions complained that it sounded...well, just cheap. Then again, some are happy with the discount variations so to repeat, highly subjective.
TommyV44 (08-19-2021)
Mine is very similar; TopGear center delete, TopGear valved mufflers, Topspeed 200 cell cats, in that order. The cats make the biggest difference and it is now finally loud enough that I sometimes close the muffler valves which I basically never did when it was just the mufflers and center delete. If I had to do it all over again I would just do the valved mufflers and cats. But as they say, opinions are like ***holes and exhausts are the same...one person's bliss is another's nightmare.
Basic Sponsor
In my opinion, the best system to start freeing up some sound would be a Center Muffler bypass.
You'll get some small HP gains and a much more aggressive tone.
Dood, your car sounds good and looks good. Nicely done. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Here’s the iPE on my car.
The following 3 users liked this post by scadams:
When I did my 2006 Carrera S, Budget wheighed heavily on my decision. I ended up with Armytrix High Flow 200CPI Catalytic Converter X-Pipe with Agency Power Headers feeding Porsche Sport Valved Mufflers.
I like the sound when not in sport mode, I do not notice a drone, but the expected wail over 3000 rpms. However in Sport Mode, Something is up in the 2500-3500 RPM range where it seems to cut out or just drop it's tone. Sport mode is a bit aggressive, so I use it when my ego needs it, but am conservative with it.
John
Also forgot to mention, my car is always throwing codes on the cat sensors now. I can clear with Durametric, some time they stay off for awhile, others they code quickly - Help anyone?
John
@scadams Have you had any CEL problems with the iPE headers?
maekwl (08-21-2021)
Fabspeed Motorsport (08-23-2021)
Thank you! I bought a factory switch panel with the PSE button but could not find the pins to connect it to the wiring harness so I control the muffler valves with my unused Homelink buttons. I also have the fobs that came with the valved muffler system but the Homelinks are easy enough to program.
Couldn't agree more. Too many stories here and elsewhere from people buying new side mufflers or modifying the original ones while leaving the center muffler alone and being disappointed. Both the side cans and the center muffler need to be addressed to freeing up the sound imo.
The center muffler is nothing but a restrictive lard can. Get rid of it.
Tubi side mufflers coupled with a rear crossover. Perfect for a 997.2
