Drive / serpentine belt broke - cost to fix?
Old 08-06-2021, 05:30 AM
MarkTro
MarkTro's Avatar
Default Drive / serpentine belt broke - cost to fix?
So last weekend I had my 2008 997.1 C4S cab at the Atlanta Experience Center. While getting after it, quite literally in the middle (both of the track and off the session) my drive belt (I’ve known it as a serpentine belt in past vehicles) broke.
the car had to be towed to a local service center. I’m wondering what the repair costs might be, if this is “normal,” and should I be worried in the future?
Any input is appreciated.
Old 08-06-2021, 08:12 AM
platinum997
platinum997's Avatar
Assuming you didn't overheat from no water pump you should be fine.
The belt itself is maybe 50 bucks. I would do the tensioner and bolts too so maybe 250 in parts. It's a easy DIY job but expect to pay 200-300 labor.
The belt is a maintenance item. Everyone has a different opinion on when to replace. Believe the manual states 6 yrs/60,000 miles.
good luck and let us know how it goes.
Old 08-06-2021, 08:20 AM
Carreralicious
Carreralicious's Avatar
The drive belt part itself is not expensive. You can get the part for under $50 and do this yourself if you wanted. Instructions are shown below. The dealer will probably charge you a nice penny, however, to do the job. They’ll prob charge you $250-300 for labor and the part itself or even suggest you change out some bolts/pulleys while they’re at it is my guess.
Drive belt replacement on 997:
https://rennlist.com/how-tos/a/porsc...ne-belt-383725
Old 08-06-2021, 09:33 AM
Quadcammer
Quadcammer's Avatar
Received 1,406 Likes on 814 Posts
Bigger question is why it broke. Modern serpentine belts are pretty strong and long lasting so id make sure none of the pullies are seized/damaged before just installing a nee belt
Floyd540 (08-07-2021)
Old 08-06-2021, 09:38 AM
hatchetf15
hatchetf15's Avatar
Received 1,028 Likes on 636 Posts
+1 to Quadcammer comment. Check the old belt and find the failure point. If the car’s at a shop already, the techs should be capable enough to devine the reason for the break.
Old 08-06-2021, 11:29 AM
BLU997
BLU997's Avatar
Sorry to hear you broke a serp, like the other posters here, I agree these belts are generally indestructible, to a certain extent.
The failure of the belt is the obvious part, but there may have been an underlying cause, a dying pump or pulley placing an extra load/twist/friction on the belt.
A P car specialist would see this stuff all the time, know that the cause is, and fix it in a way you shouldn't have to worry about it, or any other bits around it for another 60K miles.
Old 08-06-2021, 03:57 PM
MarkTro
MarkTro's Avatar
Thank you all for the input. Waiting to hear now what they say. I really wanted opinions on the general cost so I knew what ballpark to be in. It's at Porsche of South Atlanta. As soon as I know, I'll post so you guys can learn from the info too.
Again, much thanks!
Old 08-07-2021, 02:58 AM
sandwedge
sandwedge's Avatar
Received 1,041 Likes on 736 Posts
My thought too. Had a belt failure on my -09 C4S which was due to a seized up water pump. Is there such a thing as a water pump about to seize up, putting stress on the belt causing it to fail before the pump fails?
Old 07-23-2024, 02:15 PM
wbauer2
wbauer2's Avatar
I just had my car at my indy to look into an issue with the steering column and when doing an inspection to look for an occasional squeal from the back end, they have recommended replacing the serpentine belt and tensioner. The cost seems quite high (nearly $900 CAD). I have no problem replacing the belt myself, have found numerous DIYs to help. My question is - do I need to replace the tensioner and other rollers? The tensioner itself seems like a job and "baby hands" are needed to get at the bolts.
Thoughts on just doing the belt?
Note - the tech said that the belt was "glazed" and as far as I know it's never been replaced (so 17-18 years old).
Symptom - on a drive a couple weeks ago, there was a good squeal from the back. I've driven at least a dozen times since and nothing.
Thoughts? Appreciate opinions!
Old 07-23-2024, 02:25 PM
platinum997
Sounds like the tensioner has never been replaced either. It recommended to do both with the age. With that said, they sure its the belt and not the water pump? If that has never been replaced, I would do all 3 while you're in there. Cheap maintenance and peace of mind.
Old 07-23-2024, 02:42 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,567 Likes on 941 Posts
2009 C2S 201K miles
Well... this brings up all kinds of questions. 17-18 years ... that is like neglect. I recommend going through Porsche recommended maintenance schedule (prescribed in both miles or time) and do all the work required (or neglected). This may include oil, plugs, brake fluid, etc. Given its age, I would also seriously consider changing other fluids such as power steering, coolant, and transmission. If your car is a .1, 2008 and prior, I would replace the water pump as they are a troublesome part.
Regarding the tensioner, there is no reason I am aware of to replace this based on time or miles (in my opinion). Its health can easily be determined when the belt is out.
Peace
Bruce in Philly (now Atlanta)
Old 07-23-2024, 03:54 PM
4Driver4
4Driver4's Avatar
I guess it depends on your risk tolerance. This is my roller and belt. Lost it in heavy traffic at a highway speeds. I was lucky enough to find a safe place to stop before the engine overheated.
Old 07-23-2024, 06:09 PM
wbauer2
wbauer2's Avatar
Yikes! glad that you were able to pull over!
Bruce - what do you take me for?!? HAHA! Maintenance has been kept up. Plugs, coils, brake fluid, transmission fluid, engine oil, coolant expansion tank, alternator, starter motor, etc etc all within the past 2-3 years (except oil which is annually) I replaced the water pump in '21. The belt however has never been on my radar and has never peaked the interest of a tech when I have brought it in before.
Old 07-23-2024, 07:02 PM
Bruce In Philly
No offense intended. The belt is a standard, published maintenance item with a 40k mile or 4 year interval. It's replacement is in step with other items and as such, included in maintenance packages. Pretty standard stuff.
Peace
Old 07-23-2024, 09:48 PM
TurboTime997
TurboTime997's Avatar
Back in late 2020, I purchased my 997 turbo. It had 18k miles and change. Who would think that the belt or anything else needed to be changed, right? About a month into ownership, I proactively did the air filter, fuel filter, and drive belt. Whelp, when I took the belt off, some of the ribbing on the belt was missing. So don't forget the drive belt when you're doing other regular maintenance.
Quick Reply: Drive / serpentine belt broke - cost to fix?
