As I recall, water to temp and oil temp off the peg.
I just drive mine in sport mode and the car handles the revs perfectly for warmup, but I have a PDK.
Took the words out of my mouth. For PDK cars, auto/sport mode takes care of the warmup with no attention required shifting right around 3,000 rpm. Takes a while for the oil to get warmed up though, even in Florida summer heat.
2006 S here, start it, wait about a minute while I settle in, put my music on etc... till the rpm drop (idle), then cruising not exceeding 3k till the needle is at/near 200, and even then its a gradual increase (4-5k) till its been at 200 for a few minutes. Ive had a few times where leaving work there are eager cars around me that are anxiously waiting for us to get to open road (out of the base/school).. and I just let them throttle by lol. Do I want to ? Yes, but I'm not touching over 3k till the car is warmed up haha
Totally unnecessary. Once oil is at 180 youre good
oil temp at 180 is my release the beast threshold, which happens after about 10 minutes since I run a deep sump oil pan and low temp thermostat. Always between 2,000 and 3,000 rpm during that time - not higher, not lower, and light throttle use.
I do the same. Technically the motor isn't "warmed up" until the oil is hot, which usually happens 5-10 minutes after the water reaches operating temp = I don't do any serious revs until this point.
I rarely see over 200 in my 997.2 unless I am flogging it.
I normally let her rip above 180
I don't get over 200 in mine either, unless it's hot out or I'm on it. It seems to me that once the oil is at 175, it's fully doing its job- it's probably pretty liquid as soon as the needle starts moving, but in my car it moves pretty quickly past 175 once it starts moving.
Here is my process:
-Get in, get situated, check my blood pressure for increased heart rate
-Turn the key in ACC and check the oil level. Add if necessary
-Start her up, idle and wait for the idle to drop
-Start driving it under a mild engine load while keeping under 4K RPM until the oil temp is at 200 degrees
-Once the oil is up to temp, let her rip
I took the same approach on my 08 C4S Cab here in Colorado, especially in the winter months, 2000-3000, except I tried to start it and let it idle for 30 (min) to 90 seconds to let it warm up a tiny bit - until the idle dropped from 1250 to 750. That is I believe per Porsche recommendations. I didn't always run it till the idle dropped, but I tried to. It can take up to 2+ minutes.
There are many posts about this topic and the only thing common is to keep RPMs under 3k until close to 200.
Whether or not to let it warm-up at idle varies by person .I start and go and keep her under 3500 until shes close to 200 oil temp
My owner's manual states the following (on page 77): {I have a 997.2}
"When starting the engine, be ready to drive immediately. Drive the vehicle at moderate speeds and avoid engine speeds above 4,200 rpm during the first 5 minutes."
Here is my process:
-Get in, get situated, check my blood pressure for increased heart rate -Turn the key in ACC and check the oil level. Add if necessary
On a 997.2, you can't check the oil level unless the engine is at operating temperature and is idling.
