Suncoast 991.2 steering wheel hack
Old 02-04-2023, 12:24 AM
  #46
ATX_Native
ATX_Native's Avatar
Wheel came today, airbag is on its way.
No sport controller on the wheel I got! Love it.
TerrestrialFlyte (02-04-2023)
Old 02-04-2023, 12:27 AM
  #47
Goose 993
Goose 993's Avatar
Awesome. what VIN did you use when ordering? maybe that's why no SC dial?
Old 02-04-2023, 09:57 AM
  #48
frybear
frybear's Avatar
I did not go this route, although in hindsight, the suncoast deal might have been a bit of a better deal. Anyway, I recently swapped out my black spoke inserts (just plain black, no little bolts in them) for the black with bolts. If any one needs a full set let me know. They are in perfect shape. And for some reason, the plain set is quite a bit more expensive than the set with the little bolts, no idea why. Shoot me a PM if you need a set.
Old 02-04-2023, 10:54 AM
  #49
ATX_Native
ATX_Native's Avatar
I used my VIN, that might have done it.
Old 02-04-2023, 11:06 AM
  #50
frybear
frybear's Avatar
Originally Posted by ATX_Native
I was going to wait and see to see if that SC hole was even visible.
I went with the black T piece and the brushed aluminum (which I was going to paint or hydro dip the same 997.2 trim color) inside the spokes.
If it’s an issue and I can’t pick up a used T trim or could bondo the plastic sand and hit it with satin black or hydro dip it.
Will know more when I get it in my hands.
I have the chrome T piece and the other day decided I want black. $420 for just that piece from Suncoast. Pfft. 300 grit sandpaper just to scuff it a little and 12 coats of SEM spray black trim paint and it looks amazing!
The following 3 users liked this post by frybear:
ATX_Native (02-04-2023), Goose 993 (02-27-2023), joes c4 cab (02-19-2023)
Old 02-06-2023, 11:33 PM
  #51
THE Z MAN
THE Z MAN's Avatar
What is the closest color to sand beige?
how close is luxor?
So you go with 995+the mf option(700) if you want to add the mf to your current 997.2 wheel?
Thanks!
Old 02-17-2023, 10:27 AM
  #52
ATX_Native
ATX_Native's Avatar
Almost done with the wheel, should go on this weekend.
BTW, had to order/replace the rear trim pieces for the left and right sections of the wheel.
The Multifunction rear trim had a cut out, this gets rid of that.
Almost done!
Top trim is the MF Trim, bottom is the new trim.
Still cheaper to buy a GT MF Wheel to convert to non-MF.
The following 2 users liked this post by ATX_Native:
850tgul (02-17-2023), TerrestrialFlyte (02-19-2023)
Old 02-19-2023, 02:53 AM
  #53
joes c4 cab
joes c4 cab's Avatar
could you post a pic? I have the same issue. It’s too chrome for me and I have thought about painting it.
Old 02-19-2023, 10:04 AM
  #54
frybear
frybear's Avatar
Here ya go. I use SEM Trim Spray Paint off Amazon. 12 light light light coats.
joes c4 cab (02-25-2023)
Old 02-19-2023, 10:09 AM
  #55
frybear
frybear's Avatar
So I now have an extra chrome T piece and the three all plain black front and rear inserts if anyone needs a set. The bottom insert is actually for a heated wheel (which I don't have) but you can't really see the button
Old 02-19-2023, 10:15 AM
  #56
frybear
frybear's Avatar
FWIW, the plain black trim pieces from Suncoast are quite a bit more expensive then the chrome or black ones with the little bolts in them on the front. No idea why. And for me the ones with the bolts look sportier/better.
Old 02-19-2023, 02:47 PM
  #57
ATX_Native
ATX_Native's Avatar
I knew the bling inserts or the bling front while cover was not for me due to lack of bling in the 997.
So I got the black inserts and painted mine a color similar to the bezel trim, did a search and some sleuthing on Rennlist and saw a member mention Nissan KR2 Interior Trim Paint as a dead on match. I agree, it’s perfect.
Then bought an extra airbag trim ring from BobZ on here, he painted it satin black. I sanded it down and finished it in matte black. Then removed the bling ring by prying it up and placed the matte black ring in its place.
So happy with this wheel. My car has the multifunction from the factory but the MF modules to me are limited in function and our radio has a ****, also wanted a simple/clean look.
Now just need to throw it in.
The following 4 users liked this post by ATX_Native:
850tgul (02-22-2023), frybear (02-19-2023), Graufuchs (02-19-2023), TerrestrialFlyte (02-19-2023)
Old 02-19-2023, 03:46 PM
  #58
TerrestrialFlyte
TerrestrialFlyte's Avatar
@ATX_Native, looks perfect!! Would like to see it in situ.
ATX_Native (02-21-2023)
Old 02-21-2023, 09:52 PM
  #59
ATX_Native
ATX_Native's Avatar
All done! Couldn’t be happier.
850tgul (02-22-2023), 997.2cs (02-24-2023), Dubber (02-24-2023), TerrestrialFlyte (02-22-2023)
Quick Reply: Suncoast 991.2 steering wheel hack
