Semi solid engine mounts. Who got em, what do you think about them?
I have the RL Semi-solid Tunables with the softest bushings. It helped a lot with engine slop on aggressive turns, but added a good bit of vibrations. I kept them as for me the trade off was worth it, but be prepared to have some buzzing in the cabin from vibrations that you did not have with OEM mounts.
I have a really annoying buzz that I have tracked back to behind my headliner just forward of my rear window. I am wondering is it has anything to do with the rooftop antenna which I am guessing was for GPS...
Have the RSS ones. Very happy with them.
I've considered replacing mine with OEM also. I've read however that the OEM units don't hold up very long - and comparatively soon, you end up with newer weak mounts.
May want to consider going with Function First mounts. I've read quite a few good reviews on them from fellow Rennlisters who have installed them.
http://www.function-first.com/produc...-mount-upgrade
Bob
Ironman88 (02-18-2021)
Had the same thoughts, @Ironman88. Likely do the Function First engine mounts, shifter cable ends and, possibly, transmission mounts.
Bob
Bob
