DIY: How to clear sunroof and body drains on a 997 Coupe
Hi guys. After dealing with water intrusion issues on my Cayenne, I decided to check the drains on my 997. There isn't much info on how to clear the sunroof and body drains on the 997, so I created a video. Hope this is helpful for others.
Overall, the process isn't too bad. Here are the general steps:
1. Clean the 4 body drains by the battery. Simply remind l remove the plastic battery cover and surrounding panels.
2. Clean the front sunroof drains using warm, soapy water. Pour a little at first to make sure the drain isn't clogged. If it isn't, flush about 1 litter of soapy water in each drain. If it is clogged, allow the soapy water up penetrate and break up the blockage. If that doesn't work, insert weed whacker string into the drain hole and aggregate the blockage. If that still doesn't work, insert the weed whack string into the other end of the drains, which are located behind the front fender liners.
3. Clean the rear sunroof drains, which are located in the rear wheel wells towards the engine by inserting weed whacker sting.
Let me know what you all think of this method.
Cheers,
Dennis
Cheers,
Dennis
The following 14 users liked this post by dc2000:
andino (01-23-2021),
atallguy (02-02-2021),
AxelR (04-05-2021),
Boston911 (01-24-2021),
Gene_GaTech (01-24-2021),
and 9 others liked this post.
Great! How bout doing one for a cab?
I've been sub'd for the past few months. Great content! Thanks for putting this out! I had i$$ues years ago on a Audi allroad and sunroof drains. I'm scarred for life!
2009 C2S 168K miles
I have a technique for roof drains... blow them clean. Read here:
https://rennlist.com/forums/997-foru...-tool-diy.html
Peace
Bruce in Philly
Peace
Bruce in Philly
Can I borrow your car?
With the top partially down, you'll find a drain on each side underneath the top cover. You can put warm soapy water though that. The drains exit in front of the rear wheels in the wheel wells. There could be other drains, but those two are the main ones.
2009 C2S 168K miles
Peace
Bruce in Philly
Peace
Bruce in Philly
Blowing compress air through is okay if you're doing it all the time and are sure there isn't a clog, but I agree that the weed whacker string plus warm, soap water is the safer option.
If you are worried that blowing it out may blow apart the line, just poor some water down there... if it drains, albeit slowly, you have a place where the air pressure can go. While I have no proof other than my success on my own car, I doubt that you will blow the line from its mounts.
Peace
Bruce in Philly
