Numeric shifter... or not.
Old 05-24-2023, 07:06 PM
  #61
ftc3
ftc3's Avatar
I thought it was a quality product and well made but way to stiff. I had the the stiff option though. I ended up switching to the GT3 and liked it significantly better. Maybe I would have liked the lighter spring in the Numeric but I didn't know anyone with one to try it out first.
  #62
Graufuchs
Graufuchs's Avatar
Received 1,339 Likes on 495 Posts
Just ordered these: https://www.phenixengineering.com/pr...ft-bushing-kit
Phenix gave me a tracking number in 15 min, very impressed.
I have a tiny bit of slop, hopefully this corrects that. The factory throw doesn't bother me too much. If that doesn't correct the slight slop I think the Numeric will be a great solution.
Old 05-24-2023, 07:14 PM
  #63
speedracerf4i
speedracerf4i's Avatar
Phenix metal bushing will improve the slop generated from the forward-backward motion. Side to side motion slop is governed by the interaction of the shift lever with the plastic triangular side lever. Function first's shift rite kit addresses both areas of concern.
mrd_spy (06-18-2023)
Old 05-25-2023, 08:55 AM
  #64
Graufuchs
Graufuchs's Avatar
Yes, correct.
Old 05-25-2023, 01:04 PM
  #65
Scalp_em
Scalp_em's Avatar
There was a little break in period with my Numeric after installation it was stiff at first but after a while it gradually broke in and is very smooth now. At least that was my experience.
Old 06-18-2023, 12:14 PM
  #66
incoming992s
incoming992s's Avatar
Default Numeric shifter and cables
Originally Posted by oalvarez
The 997.2 that I bought came with a Numeric shifter and cables.....I will be posting the numeric shifter and cables for sale in the next month or so as I intend to install a 997 GT3 short shift kit and oem cables. I'm one that does not care for the "bolt action" characteristic of the Numeric shifter.
Regards,
Delete
Old 06-18-2023, 05:30 PM
  #67
mrd_spy
mrd_spy's Avatar
997 SS with function first kit is the best option imo,
done this in 2 of my cars now.
Old 06-18-2023, 06:13 PM
  #68
doclouie
doclouie's Avatar
Yep a Numeric shifter is awesome.
Old 07-02-2023, 12:38 AM
  #69
MJFDDS
MJFDDS's Avatar
I have a newly installed Numeric shifter and stock
cables. Didn’t notice the difficulty upshifting and downshifting into 2nd until I was at the track recently.
Could adjusting the cables at the shifter end improve the feel? Which direction should the cable be positioned if so? Im at the shortest setting so maybe that is contributing to the difficulty as well?
Old 07-02-2023, 12:48 PM
  #70
kellen
kellen's Avatar
Had function first bearings with a short shifter in my first 997. Now the numeric in my 997.2.
roughly same price. I would go with the numeric. Seems a little more tighter and I like the all in one design.
Old 07-03-2023, 12:25 AM
  #71
Rig.Stunts
Rig.Stunts's Avatar
Have you done motor and transmission mounts? With high Gs things move around enough that getting into second gear especially challenging
I have the Numeric w/cables in middle position, so I can't comment on the shortest position.
Old 07-03-2023, 01:53 AM
  #72
MJFDDS
MJFDDS's Avatar
Mounts are stock, dynamic mounts on the motor. I didn’t have this feel with the stock shifter on the track though. I’m sure the mounts need to be swapped and maybe the Numeric exaggerated the feel?
Rig.Stunts (07-03-2023)
Old 09-23-2023, 08:25 AM
  #73
kevinl964
kevinl964's Avatar
Default Installed Rohler yesterday
I took the plunge with the Rohler kit from Design911 yesterday.
Fitting was straightforward except; no instructions were supplied, there was no bolt/washer combo to hold the left cable on, luckily I have plenty of that sort of thing, needed an M5, think it was 8mm long which with the washer was fine. Also the frame has 3 holes for the centre console to fix to, these are also M5 where the original are self tappers.
Gives a nice feel on the middle hole. There is a tad of stick movement which can probably be taken away with a very thin washer on one or both sides of the stick, I may do in the future.
One thing I have found is when putting in reverse, don’t push hard (UK RHD car) whilst going into gear else this fouls very slightly on the frame and stops the forward shift of the stick. This could be a bigger issue if the top stick hole is used.
I will be letting Design911 know all
this as the overall package could be slightly improved but I’m happy from where it was.
…..now back to painting the 997.1 door mirrors for the next part of the project.
Kevin
Old 04-10-2024, 07:43 PM
  #74
Busta Rib
Busta Rib's Avatar
Received 1,105 Likes on 414 Posts
Has anyone ordered a Numeric shifter lately? How long did it take for you to receive yours? I've heard of having to wait up to a couple months. TIA
Old 04-10-2024, 08:15 PM
  #75
cloud9blue
cloud9blue's Avatar
I ordered one in Jan this year and received it in less than a month.
I do like it, but there is a reduction in the lateral throw as well, which I prefer if they didn't do that. Also, it is a bit stiff getting into reverse, but you get use to it. 1 to 6 shifting is buttery smooth but precise.
Busta Rib (04-10-2024)
Quick Reply: Numeric shifter... or not.
