Another oil analysis
#736
I don't really understand a statement that says Mobil 1 is fine, but it's viscosity is lower than it should be....that makes it not fine.
Oil really only needs to do one job - maintain it's viscosity to keep metal parts sliding past each other without wearing them out, so maintain proper viscosity for the engine's operating temperature range and show as little metal wear as possible.. If the viscosity is too low, the metal wear will suffer.
Originally Posted by B453D
Mobil1's viscosity at 100°C was less than optimal
Please keep in mind the disposition of Hootsama's post, to which I initially replied.
#737
Wear metals, contamination, add pack, detergents, and oil life were / are in the green; if the viscosity had degraded to the degree that you are concerned, I imagine it would be reflected in the UOA report.
Newer analyses to the left, older to right
#739
Does anyone have a reference to or quote where @Charles Navarro /LNE is now recommending DI40 for the M97? (The LNE website is still recommending DT40 or FR50. (https://lnengineering.com/oil.html ) I've written to LNE but no response yet. It's oil change time and I want to get the current best/recommended oil.
Rennlist DT40 v DI40
jchapura (08-13-2024)
