Show your 997 Upgraded Steering Wheel
Old Feb 16, 2021 | 11:05 PM
  #46
Sbastien BUISINE's Avatar
Sbastien BUISINE
Old Feb 17, 2021 | 11:55 AM
  #47
J.Tan's Avatar
J.Tan
Originally Posted by Gary Chan
Will be replacing my alcantara stock sport wheel w a momo mod 7 shortly.... hoping it’s not a bad idea but the wheel looks amazing! Will eventually have it recovered as well to remove the yellow stripe once everything is set up properly and I like it
I have the leather MoMo Mod.07 in mine. I absolute love it. It not only transform the look of the interior but also improve the driving position for me. The smaller diameter of the steering wheel also makes the steering feel a bit heavier which I like.
Old Feb 17, 2021 | 01:20 PM
  #48
Jaws1's Avatar
Jaws1
Ledermanz multifunction Alcantara wrap
Old Feb 17, 2021 | 01:45 PM
  #49
Shock Arrival's Avatar
Shock Arrival
Veteran: Air Force
Old Feb 17, 2021 | 03:52 PM
  #50
Gary Chan's Avatar
Gary Chan
Your car was actually one of the cars I saw including the 997 CSR that made me want it! I also ordered a similar shift **** from car-bone
did you get an airbag light? I assume you have to used the 3ohm connector? Any advice you have would be appreciated!!!
Old Feb 17, 2021 | 04:46 PM
  #51
J.Tan's Avatar
J.Tan
The car-bone shift **** is a great choice. I purchased Works Bell 997 hub kit for the steering wheel from Go Tuning Unlimited. The part number of the kit is WB-010670.
The kit comes with a wiring harness to retain the horn function and keep the airbag light off. I don't know the exact ohm in the resistor. The hub itself also has the proper cut out to clear the dummy plug on the steering angle sensor behind the steering wheel. A generic hub will require you to cut the dummy plug off the sensor.
Check out post #12 in this thread. https://rennlist.com/forums/997-foru...d-997-2-a.html
Old Feb 17, 2021 | 06:55 PM
  #52
3rd-World's Avatar
3rd-World
done by Lederman in Lativa sourced through eBay
Old Feb 17, 2021 | 08:42 PM
  #53
Khloesdad's Avatar
Khloesdad
Originally Posted by Sbastien BUISINE
What is this wheel originally from? Did you add the LED lighting? I love this wheel.
Old Feb 18, 2021 | 12:50 PM
  #54
Aclmin's Avatar
Aclmin
Looks light in color but it’s darker than it looks in the photo.
Old Feb 18, 2021 | 03:51 PM
  #55
gtfour's Avatar
gtfour
Beautiful! Is that a wrap?
Old Feb 18, 2021 | 05:32 PM
  #56
nwGTS's Avatar
nwGTS
Old Feb 18, 2021 | 08:47 PM
  #57
markmark26's Avatar
markmark26
are those Pole Position ABE ?
Old Feb 18, 2021 | 09:02 PM
  #58
J.Tan's Avatar
J.Tan
Yes, they are.
Old Feb 18, 2021 | 09:08 PM
  #59
rnye's Avatar
rnye
4th Gear
This thing looks AMAZING <3
Old Feb 19, 2021 | 10:26 AM
  #60
Aclmin's Avatar
Aclmin
Thanks - it’s maritime blue .
