My 1st 911! Modifications on the way
#32
Wipers
as a recent new 997 owner, here are a few items that are easily looked over but in my opinion provide major enjoyment now that i have replaced/added them. low cost too!
- OEM windshield wipers. couldnt tell from the photo if you have them or not, but if you don't, i highly recommend it. the OEM wipers are unique (you will find out), and just do the job perfectly
- new hood struts. it's a great pleasure to have the frunk snap open with confidence
- rennline magnetic phone mount. very solid!
#34
#35
#36
Exhaust Tips
I ordered a set of Dansk tips from CARID and the link is below
https://www.carid.com/dansk/stainles...QaAp33EALw_wcB
#37
Unfortunately, I have exhausted all my options on the Racing Dynamic Quad Tips and will be returning them. They are 2.5" ID with shims and I was not able to clamp down enough to get a firm grip on the 2" OD exhaust pipe. The shims they use are pretty crude and I feel the only way to make them work is to have them welded.
I'm thinking they might be okay for me. I have Fister Mufflers, and the coating that was used, has led me to believe the OD of where the tips slide onto has gotten larger. I had a HELL of a time getting my stock tips to go back on and deep enough to be clamped back down securely, etc.
Can anyone confirm if non-S and S model cars both have an OD of 2" for the pipe at the exhaust tips/tailpipes section?
#38
Thanks for looping us in. That's a shame they won't fit properly. But thank you for sharing your solution also, I hope those work out for you better, are those also 90mm?
https://rennlist.com/forums/997-foru...l#post13736409
#39
If the OD was 1/4" larger I think they would work fine, I like the look. The quality of the clamp is not at the same level as factory.
Based on the price I think they are great units to buy and have your local muffler shop weld them on.
Racing Dynamics
Stock
Racing Dynamics
Stock
#40
I believe on 997.1, non-S are smaller than S - might explain your difficulty. On 997.2, same diameter. My 4S OEM tips went back on my Fisters exactly as they should, no fight.
#41
Was the OD and ID size fitment the only issue you had? Or was there something else about the build of the actual tailpipes?
I don't imagine you were able to snap a picture from the rear view of the tips on at all were you?
#42
ShaunPerry (01-06-2020)
#43
Tips
Thanks Uno. I may take a swing at them myself. It seems a 997.1 S has a larger OD exhaust pipe.
I will report back on the Dansk tips when I get them
#44
Congrats and welcome!! Fellow diesel boat owner here with 2007 Silver/black "S" model - Also manual transmission.
Love the Lobster Fork Wheels! **I suggest H&R Springs to lower the car - Give the car aggressive look, bit better handling and you can still operate PASM adjustments from dash. (If you have PASM)
Enjoy!!
Enjoy!!
#45
[QUOTE=groovzilla;16337718]Congrats and welcome!! Fellow diesel boat owner here with 2007 Silver/black "S" model - Also manual transmission.
Enjoy!!
[/QUOTE
Thank you, really excited about the car so far. Mine is a base model with some nice options. Love the S I just could not find one nice enough that was in my price range.
I am seriously considering springs, but will wait and do springs and shocks together. I just got notice that my Fisters arrive next Monday. This week is refinishing interior pieces, Stereo, shifter bushings, shifter adjustment. Next week will be Alternator (slow), FabSpeed intake, FF Engine mounts, Fister Exhaust, Coil Packs and plugs. Then drive, drive and more drive...
Enjoy!!
[/QUOTE
groovzilla (01-08-2020)
