Good multi-year UOA
FYI... Liqui Moly Leichtlauf High Tech 5W40 was only in the last year (sample). All others are Motul 8100 Xcess 5W40. Yes, Motul has slightly more ZDDP, but no molybdenum; the moly readings seen with Motul samples are due to adding LM MoS2. Liqui Moly oils are rated No. 1 in Germany and routinely used in motorsports, with a solid reputation re their oil stocks and additive packages. I think that the anti-wear package is moving away from ZDDP. Molybdenum being a solid lubricant which attaches well to metal surfaces is a good thing, especially to protect cold starts.
I understand your comment about ZDDP being replaced by moly in the newer oils. I prefer to have both (all 3) which is why I use the Driven DT40 oil where I don't have to add anything foreign to it.
Yes, I understood that from your initial post. What I was looking at was your Motul ZDDP numbers vs my Motul ZDDP numbers. With 1,000 miles more on mine per oil change, my numbers are still better, so my concern is why the anti wear properties in your oil is disappearing faster than in my samples when using the same oil. That can be (not necessarily is) an indication of engine wear.
Thanks.
Ironman88 (12-31-2019)
I checked Driven's site and could not find a single document with specifications of their DI-40/DT-40 products. No ratings/manufacturer's approvals/standards compliance, nothing.
Nope, as a boutique manufacturer that started out as a private race team (Joe Gibbs Racing), they don't submit their oils to the accreditation companies. I started using it on the recommendation of Jake Raby and Charles Navarro and the UOA reports backed up their claims so i stayed with it.
You can always look at the SPEEDiagnostix site and their New Oil Analysis page(several oils) for information on theirs(and others) addititve packages.
https://www.speediagnostix.com/new-o...acing-oil-dt40
https://www.speediagnostix.com/new-oil-analysis-results
I still use LiquiMoly in my VWs and have for many years. And did so with my '06 C2S, until the last year and then changed to DT-40. I still feel pretty good about the LM oils though.
Adias you do realize the LM 5w-40 does not contain Moly in its additive package? I have a UOA to prove this, this was also discussed on the Bob is the oil guy forum, you have to add ceramic or Mos2 to get any Moly in your reading. As Petza noted, I also had worse fuel dilution readings with the LM 5w-40 compared to any other oil ive used (Mobil, Castrol, Motul). I personally won't ever use this oil again as this oil just barely holds up to a 3k interval. The only reason its popular in Germany is that its much cheaper than Castrol and Mobil, which is the opposite case for the US.
Im guessing this is just known? Like it’s by design? Glad you guys told me. Make me happy I’m rockin DT40. I’m curious to see what my UOA looks like with the DT40. Like others here, the Motul UOA had no moly
I don't want to threadcrap Adias post, but since Snaphappy asked, This is my report with the LM 5w40 Leightlauf which has no moly, well 1,after 2.6k drain interval. As you can see compared to a prior M1 0w40 which I ran for 8k, the M1 actually has more additives and I would trust that over the LM for longer drain intervals..
Driven is a great oil and I have tested many in my track car with UOAs and none have held up nearly as well to the abuse including Motul, Amsoil, and Liqui Moly. I personally order it by the case and use it in both my track car and 911. I know lots of others who have had similar success.
Although, I don’t think you really posted looking for anyone’s opinion, you seem to know it all.
