Guide to Repairing a PDK Transmission
#1366
Not sure about the "amazing" part but I was able to do the repair on a 997 with the transmission installed. I captured DIY instructions here:
https://rennlist.com/forums/diy-997/...l#post19004433
As stated in that thread it is very doable. While access is a bit more limited than the other platform it's not that bad. As a matter of fact, gaining access to the transmission case is easier than the on mid-engine cars. I had to modify the pull/press tools a bit to work on the 911 transmission but in the end these are pretty simple tools that any shop could easily make.
So I have to ask, why are shops charging around $4k (or more) to do this work? stjoh has shown it's about an eight hour job tops, particularly if one has a lift. The guy @jjrichar mentioned up in comment 1357 says his distance sensor "fitment service" is 6750 pounds ($8500 US), marked down from the normal price of 13,500 pounds. Absurd.
Look at what @stjoh demonstrated:
- The PDK does not have to be removed from the car
- The coolant does not have to be drained and refilled
- The PDK clutch fluid does't have to be drained aside from the small amount lost disconnecting the heat exchanger (gear oil does but that's a simple drain/refill)
- There is minimal ancillary components/hardware that needs to be removed for access
So why are shops charging four grand? Eight hours at $150/hour is $1200, at $200/hour is $1600. Again, why four grand? Please don't tell me it's from overhead as those $150-200/hour rates are burdened, they include overhead. The mechanics aren't getting $150-200/hour as that would equate to $300k to $400k a year.
It seems to me the prices aren't being set by the actual labor involved, but by what people are willing to pay compared to a new transmission. That's fine if that's the case but then let's be honest and tell people the actual labor rate is closer to $500/hour.
#1367
Karl.
#1368
If people know that it could be almost 20k repair, to hear it could be done for "only" 8 is a relief.
#1369
Basic Site Sponsor
Basic Site Sponsor
Trying to compare DIY pricing to shop pricing is highly misleading. A DIY’er might get lucky and get away with a bunch of shortcuts and it works out, but 9 times out of 10 there are other issues and thats why shops need to charge accordingly - you're paying for experience and expertise to fix those issues. I cant begin to tell you how many calls I get from car owners and other shops (including overseas) begging for help because they tried to do a sensor replacement and bricked a TCU or had another issue that they cannot resolve. Calibration issues are frequent and without a dealer level PIWIS there are cars that cannot be calibrated properly.
Todd Lamb
Atlanta Speedwerks
www.ATLspeedwerks.com
Porsche repairs, servicing, and upgrades / Certified IMS installer / PDK repair experts
Over 150 PDK's repaired and counting: https://youtu.be/m54P_zisEcI
Todd Lamb
Atlanta Speedwerks
t-design (09-14-2023)
#1370
Update by my side:
Porsche tell that is not the harness or the valve body as sd before,. Yesterday they tell me that they want to try to change TCU, but by their experience the problem will not be solved, so i must change entire PDK (12/13K€) They offer also to me the possibility of buy an used pdk (searching by myself) and they will assemble it on my car (1400/1500€ only porsche work + an used pdk 3/4k€). Otherwise t-design workshop in italy ask me 8k for entire work on my car.
@PV997 @jjrichar My question for you are:
My gearbox (981 gts without limited slip) might be 9G230001125,
- the last two numbers (25) are only revision index? Can I assemble a PDK with different last two numbers?
- can i assemble a pdk with limited slip diff? (9G2300021xx)?
Thanks so much
Thanks so much
#1371
An other question:
If i change distance sensor DIY, it is ever required to calibrate it? Or in some cases is not necessary?
what is the price of sensor? and who sell it? I know only T design.
Mirko
Mirko
#1373
Don't know about the revision numbers on the transmission part number. I can't see there being an issue if you use a transmission from another 981 that is the same variant. I can't find any part lists for the GTS, but the part number you quote is for the CG2.25 transmission, which is the non LS version that is also on the Cayman/Boxster S. So you would need to find one that is the same variant, that being a CG 2.25. A transmission from a base Cayman/Boxster is a CG2.05 and won't work as the gearing is different. I suspect you could happily install the transmission with the LSD, but then would need to program with PIWS that the LSD is installed.
#1374
It can sometimes work without a cal, but personally I'd recommend always completing the cal without part replacement so the distance sensor outputs are accurate. Otherwise I think there is the risk transmission damage if there is an incorrect gear engagement that isn't picked up by the TCU due to inaccurate distance sensor numbers.
I'm seeing your piwis video and installing on VM, which interface should i buy?
i see on chinese site various interface at 70$, i don't know if i can post the link, are them ok for pdk calibration?
there are various version, 5054A, 6154 both usb or bluetooth or wifi, and there are written various release 1.6.6 ,1.8.4 i'm a little bit confused, i also read on some site (maybe T-design) that piwis 2 is better than 3 for this procedure
#1375
Thanks againg Richard,
http://www.obd2store.com/original-sa...te-p-1984.html
I had purchase previously another interface that consequently failed, was fixed, failed again etc. Internally it was different to the one I currently use. It was also less expensive. Whilst this seller would get back to me promptly, it was clear the interface design was not as good.
So I don't have a recommendation unfortunately. There might be others here who have had a good experience with a vendor and can provide a solid recommendation.
#1376
Link here for the interface I bought. Whilst the interface works well, when I was having a few issues I attempted through various means to contact them. I couldn't get any response and they fully stone walled me. For this reason I would avoid them, as you are going to be on your own if problems arise.
#1377
It tends to do that. I don't know why. Might be a google drive thing due to it being a large file. I think the best chance of success is downloading during an off peak time.
#1378
anyway today i taked back my car from porsche, they asked me 375€ only for diagnosis. In the morning they tell me at telephone that it will be 160€, when i ask them why is there that difference they can't answer me...
There is also a scratch in rear bumper that isn't there before, and they returned the car to me with the battery completely low.
Tomorrow they will hear from me!
Back on topic, once at home i've done some test, DC VOLT from pin 19 and pin 4 (TCU) is 4.2V if connected and 5.0 if i remove wire 19 from connector, so i really think that the problem is distance sensor, tomorrow i will order it..
#1379
I have replaced distance sensor and all was good, i put the car in rolling test mode and all gear was working well R included.
after that i have performed calibration and it fail at 58% "65008 - unexpected routine result for service teach_in_shaltstangen_requestroutineresults"
I now have a red warning and gear locked in P
Tha only fault in memory is p1870 and the distance sensor is reading -0.328 0.441 0.488 -0.746
What can i do?
What can i do?
#1380
I took delivery of my 981 in November 2013, so I had a gen1 PDK. My PDK failed in January (https://rennlist.com/forums/981-foru...nsmission.html), and was replaced with a re-manufactured PDK. I am curious if the build quality on the PDK will be improved over the gen1 PDK which died, or is it a like-for-like change, with the same risk of failure?
