Guide to Repairing a PDK Transmission
#1126
Here's where my lack of knowledge of your transmission shows itself. Where are the pressure sensors? On the VB? In the sports car transmission they are behind the clutch pack.
Regardless, it shouldn't be leaking. No electrical problem from what I know should ever have oil come out of the bell housing. Again, this is just speculation on my part.
I agree! I don't think the electrical problem is causing any leak, I'm wondering now if this is a totally unrelated problem. Now the question is why aren't the gears engaging? Is it possible a bad pressure sensor could cause the system not to let gears engage? At this time the error codes are the pressure sensor and the p17d1 or gear can't engage codes - its a couple others that have to do with hydraulics.
My only thought now is to swap pressure sensors since theyre the same part and see if the code switches to sensor 2.
#1128
None of those errors are currently present. Prior to starting the engine to start the cal did you delete all codes? Any cal I've done before always needs codes deleted prior to starting or it will always fail. There are a few codes that it will complete the cal, but only a handful, and it's lists them when you start the cal procedure.
Also, if it's easy to get to the sensors, then swapping is an easy way to diagnose if one is bad.
#1129
The procedure for the Panamera might be slightly different because it doesn't list anything before cal. But those codes popped up right after calibration failed.
Also maybe the issue is I tried to delete them with the car on. I can try again and see.
are you saying they aren't present because they're greyed out?
#1130
I just want to give an update on my PDK journey - finally, the PIWIS 2 arrived and I did a clutch "recalib without parts replacement" and viola! The car is reversing properly again!
So the pattern is identical to the 1st time I ran into this problem - car threw error codes P0700 (Transmission control system (MIL Request)) and P1734 (displacement sensor), "transmission emergency run" message plus CEL on the dash, and couldn't reverse. Those codes can be cleared but a P1764 (Engagement block, synchronization or gear skip (No fault symptom available) would remain and still cannot reverse, but a recalibration with PIWIS 2 will put it back in working order.
My theory is my distance sensor is on the verge of failing and is giving intermittent erroneous readings, whenever it does somehow that throws a wrench to the clutch calibration. I found it somewhat interesting because I have read a few occurrences of intermittent distance sensors failure before they permanently fail, but in those cases, cars would be drivable simply by restarting the car after the intermittent failures, I haven't seen other people mentioning the car would need a PDK recalib after the intermittent failures. I thought my case is a little interesting in this regard and worth sharing here, in case other ppl run into similar pattern, might found temporary relief by doing clutch recalibrations.
I'm inclined to get the sensor replaced anyway now, even though the car is drivable for now after recalibrations. My thinking is just to follow the most obvious clue - if P1734 came up twice it is likely the root cause of the problem. Better do this now while the car is somewhat drivable than having to deal with transporting the car/getting stuck in a random parking lot when the sensor permanently gives out...
One side of my brain knew this is what likely would happen if I kept driving the car before having the sensor replaced, but the other side wanted to keep pushing my luck and experiment, and this is what it is now - intermittent sensor error turning permanent.
#1131
One, even though the car isn't moving the input signals for vehicle speed is at 2.74 km/hr with engine off and will sometimes jump to 655 and a fraction when engine on. Clearly this seems to be an issue since the system thinks the car is going, right?
Two, the pressure regular 7 I see will jump from 0 to 1 mA as the car is running, all other ones are receiving more current.
I'd very much appreciate your insight here: where do I go to check the pressure regular 7 output signal? Is this a valve body thing? And finally I'd love your input on these things I noticed. Am I overthinking lol or is it possible these issues could mess with vehicle going into gear?
#1132
Now your pictures above of the tools used make sense. I had no idea this was how it was for the earlier transmissions and since they had moved to circlips. Really nice to know.
As to your question, I'd be doing my best to crimp with what you have but also use some red loctite to ensure it can't move. It would be pretty simple to remove the rear plugs at some stage later to visually check the nut isn't backing off.
I would love to hear some guy somewhere tell us something like "a 1948 Dana spindle nut socket fits those nut slots perfectly" or some such thing, but a hook spanner can't be used because it's back in the aluminum bore of the case and using a chisel and hammer to the slots just would be akin to an unnatural act. But there doesn't appear to be many DIY repairs being done at this time and the Indies have remained silent. So, I fashioned a socket.
The proprietary nature of certain parts is fascinating to me; why Porsche made the design choices they made. I mean really, M8x50 aluminum oval head screws they don't use anywhere else in their product line - or anyone else's product lines that I can find - and an oddball M33-1.5 stake-rim slotted bearing retainer nut, they changed to a snap ring the next model year? And why their Procurement Managers made deals with the suppliers to keep certain parts from the public standing on the other side of the Parts counter. I understand the buyer's deal more than the designer's but will never appreciate the business managers that orchestrated the whole thing. OK, admittedly I might need therapy to get over it. Rant over. I'll press on.
But really, if I had 10 cents for every time as a technician I asked the designer, "what were you thinking?" They usually had a good explanation for it in the industry I came from, but the reason was not apparent at first or second glance.
Keep up the good work and thanks for the prodigious contributions, Jeff. It spurs me on. ~Cheers!
#1133
Another update - same errors (P1734 & P1764) came up yesterday, only this time I can't seem to clear them and they reappear as soon as the car start, with those errors there I can't do a transmission recalib. Also, this time seems like it's having trouble getting into forward gears as well, not only the reverse. It's still not acting very consistently - yesterday I managed to get it into gear occasionally and made it back home by starting the car/putting it in gear multiple times, going to play with it more when I got time but I think the sensor is really quitting for good this time and I might need to have the car transported to the shop that will do the sensor replacement for me instead of driving there
So for example when doing the cal 1st is selected and the response from the distance sensor is 9.0mm. Afterwards when driving you put it into gear, it selects 1st, but for some reason the distance sensor response is 8.0mm. The TCU says 'that's not enough', so it skips the gear and moves to the next, and will continue to do so until it finds a gear that it's happy with. With our prototype the response was too sensitive. When I installed the OEM sensor after the prototype testing, I didn't do a cal and selected 1st, the response wasn't enough. After the cal from the prototype it was looking for a distance of about 10mm, but the OEM sensor response was only 7.5mm, After selecting 1st, I rapidly saw it automatically select 2nd, 3rd and then finally 4th where it found a gear where the response was enough compared to the cal from the prototype.
What was interesting is that the TCU logic seems to be that it's looking for a distance that is not less than what is stored from the cal. eg. If looking for 7.5mm and it gets 10.0mm, it seems to think this is OK. If looking for 10.0 mm and gets 7.5mm, it says that's not enough, the gear hasn't engaged hence the failure.
So your symptoms point to doing a cal and getting all the numbers in the TCU, but later when gears are selected the response is different. The 1734 will occur when you get an implausible response from distance sensor 4. To me this all points to a distance sensor issue, with the response being either at times inconsistent or at other times implausible.
Have you tried unplugging/re-plugging at the transmission and also the TCU? I've had issues with this type of signal with other transmissions that was just a contact problem at the plug. Moving the contacts to get a good connection immediately fixed the issue.
#1134
Two things I noticed today that're very odd.
If so, there seems to be a significant electrical or TCU issue if it's not talking to other control units in the car. It might just completely shutdown due to the low pressure problem. It's hard to know the follow on effects when something significant fails. My approach would be to find the source of the leak and fix that first. This is the known problem, and if it's causing a low pressure throughout the remainder of the transmission, this might be causing the issues.
If you turn the car off, disconnect the battery, reconnect and then get into the TCU with PIWIS without starting the engine, can you clear all the codes? The TCU and DME can't have codes cleared with the engine running.
#1135
It won't be true quite yet, but at some point in the future, it will be likely that the contributors to threads like this one will know more about the 997-era PDK's internal operation than anyone at Porsche AG. ZF is likely keeping secrets from their customer, just as that customer keeps them from us.
12gauge (01-25-2023)
#1136
Sorry I can't be more help but the Panamera PDK is a much different beast than that used on the sports cars. I don't have much info specific to it.
#1137
During our testing of our new sensor and then installing the OEM again, we've learned a bit about what the 1764 code is about. When doing a cal, it pushes each shift rod into each gear and sees what the corresponding response from the distance sensor. It stores this and then is looking for this each time a gear is selected. It also seems to look at the response with other possible gear pre-selections, as adjacent magnets can affect the response.
Also, yet another update - i left the car overnight, tried again, managed to clear 1734, and did a calibration, and now it's working again.
I can try to unplug those if it's easy to get to, see it would stop 1734 from coming back...
#1138
No I have not tried unplugging the transmission or the TCU - are those plugs easy to access to?
Plugs on transmission are pretty obvious. The one you want to find is at the rear of the transmission (towards the front of the car in a 911). You don't have to completely disconnect. It has a lug on the side of the plug that you just rotate, which will move the plug rearwards and move the contacts against each other. Just move the lug back and forth a few times and then return to the original position. If you can see any oil or fluid that might have gotten into the plug I'd disconnect and clean with contact cleaner.
It's a long shot doing this but the simplest thing to start with when getting inconsistent output from an electrical item.
#1139
Other 997 owners will help on where the TCU is in your car. PV?
This picture shows the side trim still in place but it's easier to just remove it IMO (I have a Cab, may be different on Coupes). If you unhook the strap over the TCU it will lift out and make accessing the plugs easy.
#1140
But I will try to see if I can give the connections a checkup...
